01-10-2018
00:05
07:03
FerdinandFitbit
01-10-2018
00:05
07:03
FerdinandFitbit
Hi everybody! I don't usually uses blaze while I work. I put it on the table. After about four hours, the blaze turned to 60% batteries from 100%. Any power-down mode can I use in the blaze?
08-01-2020 18:44
08-01-2020 18:44
08-02-2020 01:23
08-02-2020 01:23
Facing the same issue. Guyz please help & advise.
08-02-2020 01:45
08-02-2020 01:45
Search my past posts.
You can solder in a new battery
Find someone to do it for you
Get a different brand
Or pony up to fb more $ and hope for some reason they don't do it to you again later.
08-02-2020 04:57
08-02-2020 04:57
09-15-2020 12:57
09-15-2020 12:57
I think that battery is draining fast, because you dont have nice high voltage resistors.
03-09-2021 05:43
03-09-2021 05:43
Just an update for anyone thinking about replacing the battery - I did this and it's still draining just as fast.
My battery life just took a dive one day, I was getting 3-5 days charge out of it then suddenly it would only last around 6-8 hours (notifications, bluetooth etc. off). So I was a bit skeptical it was a battery issue given it was quite sudden as opposed to progressive.
I have a suspicion that this is some kind of firmware issue or something. I wish Fitbit would investigate it 😞 They offered me money off a new watch but I don't want a new one, I like my Blaze and if the problem is just battery life then why can't I just change the battery and continue using it?
03-11-2021 23:15
03-11-2021 23:15
Thanks will look at the Garmin as so fed up with this battery issue 👍
03-12-2021 02:21
03-12-2021 02:21
03-12-2021 07:08
03-12-2021 07:08
I've moved on from FitBit. Went with fruit watch. Whole family has them and it's been great. I loved my Blaze while I had it but it just is not worth the headache at this point.
Best of luck to you.
03-12-2021 07:20
03-12-2021 07:20
03-12-2021 07:59
03-12-2021 07:59
Every night. I put it in a holder by the bed and into nightstand mode, which I love. If I want to use the sleep tracker I put it in a charger for about a half hour before I go to bed. Never had an issue with the battery or charging and it does so much more than just fitness. Very happy with it.
By the time my Blaze was dying, I was charging it multiple times during the day. And the hassle of replacing the battery just wasn't worth the functionality.
03-12-2021 08:32
03-12-2021 08:32
03-12-2021 09:49
03-12-2021 09:49
03-12-2021 18:49
03-12-2021 18:49
03-12-2021 19:06
03-12-2021 19:06
03-12-2021 19:11
03-12-2021 19:11
04-06-2021 19:37
04-06-2021 19:37
@Bobbylillo you can use the watch to make calls without a phone? does this work on WiFi and does it provide you a unique phone number or show it as your existing? this sounds like a really neat feature!
04-06-2021 19:55 - edited 04-06-2021 19:56
@peac0ck YIKES!
Can you share which Blaze replacement battery you purchased that's only giving you 8 hours of battery life so we don't purchase the same replacement? I bought my replacement battery, a Synergy Digital brand, 120mAh through Amazon and eager to replace it soon. I have a perfectly working Blaze so my interest in replacement will allow me to compare it to an original that still gets over a week. Here's a picture of my Blaze battery:
Replacement Battery for Blaze
What do you base your suspicion about a malicious engineer targeting your tracker with intentional firmware? How, exactly, would this work? Is your theory based on an increase in the frequency of syncing or something? I mean, as this sounds paranoid delusional and interested in giving you the benefit of the doubt would like to learn your theories and thought processes behind this rather peculiar speculation. Please walk us through? Thanks!
That's awesome Fitbit provided you a generous discount on a replacement tracker.
Which Fitbit did you end up purchasing?
04-07-2021 07:33
04-07-2021 07:33
The feature he's talking about is a WalkieTalkie feature not cell call functionality. So you can use it with models all the way back to series 1. You can reach out to friends or family who have a fruit watch and have accepted your invite to join. Once they're on the contact list for Walkie Talkie you can initiate a call. You have to have connectivity through Bluetooth with your phone, WiFi, or cell.
If you get a fruit watch with cellular you can actually make cell calls. I simply added it to my cell plan and it shares the same number as my phone.
05-08-2021 11:02
05-08-2021 11:02
I know this is old, but I am now having problems with mine. So you are telling us that we just shouldn't use any of the functions of our Fitbit so that our battery stays charged? What's the point? I have had mine for about a year and use all of those functions with no problem until about the last month. Sometimes it will die but when I put it on the charger it shows it still has a charge. After it shows fully charged it lasts about 3 hours.
