01-10-2018
00:05
07:03
FerdinandFitbit
01-10-2018
00:05
07:03
FerdinandFitbit
Hi everybody! I don't usually uses blaze while I work. I put it on the table. After about four hours, the blaze turned to 60% batteries from 100%. Any power-down mode can I use in the blaze?
10-17-2019 04:16
10-17-2019 04:16
10-26-2019 10:02
10-26-2019 10:02
Blaze battery last only one day
11-04-2019 12:27
11-04-2019 12:27
11-04-2019 12:31
11-04-2019 12:31
11-04-2019 12:43
11-04-2019 12:43
My battery is draining up. I charge it and it only last half day maximum
11-04-2019 17:20
11-04-2019 17:20
If you are just going to use a boilerplate response, why not put some thought into it or at least try a direct answer. I can live with an honest: “We just hoped you would just upgrade every year so you wouldn’t notice...” It’s not nice but it would be refreshingly earnest.
11-04-2019 18:38
11-04-2019 18:38
11-05-2019 03:55
11-05-2019 03:55
11-05-2019 07:28
11-05-2019 07:28
Google just bought the company; I'm sure it's not for the app software (which kinda works sometimes) nor the firmware (which kinda works sometimes), nor the customer loyalty (which they've pretty thoroughly blown in some product lines). I expect it's for the hardware fabrication in low cost foreign regions. FWIW, I have no complaints about the blaze from a hardware point of view; I think the premature battery death issue is due to firmware charging the battery at an excessive rate, in the interest of user convenience.
I'd not expect new management to be inserted any time soon, nor any improvement of customer service toward old product lines. Maybe toward the newer, current lines, but I'd not hold my breath on that one.
I expect this sale has made the original owners very wealthy. Goes to show that in the real world, bad behavior often is rewarded. Oh well.
11-19-2019 04:43
11-19-2019 04:43
Why does my Fitbit blaze battery goes down quickly I only charged it Sunday morning and had to charge it again today
11-23-2019 15:40
11-23-2019 15:40
My battery will not last the day, it only lasts a few hours so I can’t use it anymore. Can battery be replaced? So unhappy!
11-23-2019 16:20
11-23-2019 16:20
The company refuses to do it for you, but you can do it yourself or have it done. It's not difficult. Search my previous posts; I get tired of giving the same answer repeatedly to the same question from people who do not search the thread.
11-24-2019 09:25
11-24-2019 09:25
I have tried EVERYTHING suggested and my blaze battery lasts less than an hour. It is almost 2 years old. I plug it in, and it says FULLY CHARGED in a couple of minutes which doesn't seem right. I leave it charging for a few hours, then as soon as I put it on it says it's dead.
I am assuming I now need a new fitbit?????
11-24-2019 16:26
11-24-2019 16:26
11-27-2019 04:19
11-27-2019 04:19
Thank you, I will give it a go!,
MD200
11-27-2019 04:49
11-27-2019 04:49
11-27-2019 07:40
11-27-2019 07:40
12-19-2019 14:05
12-19-2019 14:05
Help. My problem is not the charging. That works fine. My battery has suddenly started draining really quickly and doesn't even last a working day now. It seems to be something to do with the music control. I never use it but it is constantly playing silently. How do I switch it off please?
12-22-2019 09:51
12-22-2019 09:51
01-13-2020 11:22
01-13-2020 11:22
I have tried all that is recommended and my battery will only stay charged for 48hrs and decreasing!!!
