Blaze battery draining fast
ANSWERED
Hi everybody! I don't usually uses blaze while I work. I put it on the table. After about four hours, the blaze turned to 60% batteries from 100%. Any power-down mode can I use in the blaze?
905 REPLIES 905
I did years ago and haven’t looked back. Love the new fruity watch! Good luck
Sent from my iPad
I switched over to a competitive brand several years ago. More than pleased with performance and service. No issues with product or battery. Hope you are as fortunate
Sent from my iPad
Just a bit aggravating when I asked for help about the battery draining so fast.
The response should have been "The battery has expired beyond its expected capability.".
Instead of a rabbit hole of a canned response to extend the normal drainage of a properly functioning battery.
I had a fruit phone so I opted for a fruit watch. I have had this one for several years. Does all I want it to do and more. No battery issues, regular updates, etc. no issues at all. I wish you luck.
Sent from my iPad
Do you have to charge the fruit watch every night?
For the most part I do have to charge it everyday. But I track my workouts 5 days a week and it is doing those for anywhere from 3 to 4 hours per day. In addition I use it to track my sleep every night. Takes about an hour to charge. Before I started to track my sleep I had my charger on my night table and I would put it on the charger when going to bed and the first time I woke up I’d put it back on.
Sent from my iPad
