01-15-2019
13:51
12:48
FerdinandFitbit
01-15-2019
13:51
12:48
FerdinandFitbit
My Blaze is not holding a full charge for more than a day. What is the next step as I will be calling?
Moderator edit: updated title for clarity
12:47
04:04
01-16-2019
12:47
04:04
Hey there @Xlion81! 🙂 Welcome to the Fitbit Community Forums!
I'm very sorry to hear that you're having problems with the battery on your tracker draining faster than it should. I'd like to help you out!
I can recommend putting your tracker to charge and once it's fully charged, take it off the charger and put it on. Sync it and use it as you would normally do. Make sure to sync it frequently after this (every one or two hours at least) so that the battery levels are recorded on the app logs and once the battery dies, let me know so that I can take a closer look and then we can move forward with other options to get you back on track.
