12-12-2019
16:42
08:34
12-12-2019
16:42
08:34
Why does my Fitbit loses the power so quickly? It can’t hold the charge for a day, even if I charge it overnight. Is there a way to check the battery condition and replace is required?
Best Answer12-13-2019 08:59 - edited 09-25-2024 07:32
Hi there @DeepakRathi, welcome to the Community Forums. Thanks for the details provided about your Blaze's battery behavior.
I've seen you contacted our Support Team after posting here and that they have helped you with this. Please check your inbox, they sent you some instructions in order to solve the issue with the battery on your Blaze.
Let me know if there's anything else I may do to help you in the meantime.
