12-21-2018
18:30
12:54
FerdinandFitbit
12-21-2018
18:30
12:54
FerdinandFitbit
Even though the Blaze shows it is fully charged is dies after about three hours,
Moderator edit: Updated title for clarity
Best Answer12-23-2018 12:53
12-23-2018 12:53
Hi there @tiggle08, welcome to the Community Forums! 🙂
I'm very sorry to hear that you're having problems with the battery on your Blaze. I'll be hapy to help you out!
I've gone ahead and escalated your case to our Support Team for them to help you out. Keep an eye on your inbox for more instructions. If you need more help, let me know!
Best Answer12-25-2018 07:12
12-25-2018 07:12
I am having same problem. Mine lasts for 5-6 hours. Is this normal for the Blaze?
Best Answer12-25-2018 09:14
12-25-2018 09:14
I had this trouble when I first got mine a few months ago. I had the settings set so when I raised my wrist the face would light up with the movement. I set it so it only lights up when I push the button and it lasts for 4 days now.
Best Answer12-26-2018 05:52
12-26-2018 05:52
Best Answer12-26-2018 13:37
12-26-2018 13:37
I am having the same issue. Just started this week.
Best Answer12-26-2018 13:55
12-26-2018 13:55
Also having the same problem, battery draining much quicker than normal. Have the Fitbit blaze only since march 2017.
Best Answer12-26-2018 18:11
12-26-2018 18:11
Best Answer12-26-2018 20:02
12-26-2018 20:02
Thanks, but that's not the reason with mine anyway. I only open the app to sync it after the battery dies. Bluetooth in general isn't turned on on my phone until I need it also.
Best Answer12-27-2018 07:16
12-27-2018 07:16
mine just started draining the battery last week. I have tried all the suggestions and noting works.
Best Answer07-31-2020 06:02
07-31-2020 06:02
My fitbit blaze started dying out of no where after 3 hours too 🙁
Best Answer07-31-2020 08:41
07-31-2020 08:41
Best Answer07-31-2020 12:19
07-31-2020 12:19
