02-22-2017
03:07
10:04
FerdinandFitbit
02-22-2017
03:07
10:04
FerdinandFitbit
What won't my Blaze hold its charge for more than a day? It's driving me mad
Best Answer02-22-2017 06:39 - edited 02-22-2017 06:40
In your app make sure:
All day sync is not one
Turn off quick view
Do you get a lot of Notification as well
All of the above will drain the battery
@Torbagz Moving to the Blaze forum now
Wendy | CA | Moto G6 Android
05:01
09:37
02-24-2017
05:01
09:37
It's great to welcome you @Torbagz and @WendyB thanks for stopping by.
If you are having problems with your battery life, I recommend checking the instructions provided in the Tips to maximize the battery life of your Blaze post.
I hope this helps, catch you later. ![]()
