05-18-2018 19:33
05-18-2018 19:33
My Blaze battery will not hold a charge longer than 36 hours. I’ve had my Blaze for 2 years and this just started. Any idea why this is happening or how to fix it would be appreciated.
05-18-2018 20:30
05-18-2018 20:30
My Blaze will be 2 years old on Aug 2nd and has worked perfectly well until now. Not only will the charge not hold for 4 to 5 days as it once did but it will expire after only 5 to 6 hours of use. Do these things just die or can they be repaired.
Best Answer05-19-2018 08:22
05-19-2018 08:22
05-20-2018 05:43
05-20-2018 05:43
I phoned Fitbit and was offered a discount to purchase another Blaze as this one is “dying”.
25% good for 30 days is generous of Fitbit ‘cause my warranty has expired. Not sure I’ll take advantage of their offer as I also had an HR “die” on me after only 7 months.
Good luck!
Best Answer05-21-2018 16:29 - edited 05-21-2018 16:30
Mine too. Only I've only had my fitbit Blaze since December, 6months. It is only lasting max 2 days. Charged it yesterday, put it on a 10pm and it is already on less than half battery. What is the solution people? Still under warranty, so I guess I could take back to the store...Don't want another one if it is gonna to this again.
PS. I'm in NZ and our Consumer Guarantee laws mean we go back to the place of purchase, not the FitBit company itself
Best Answer05-22-2018 01:19
05-22-2018 01:19
I’ve charged my
battery just yesterday and now it’s empty and now I’m looking at
my blaze it’s fully charged again but my
iphone is not picking it up as battery full. It’s sayong that my battery is empty. Why is that? Is there some way of fixing this issue?
Best Answer05-22-2018 02:41
05-22-2018 02:41
My Blaze is 18 months old and has also just started with this problem! Charged at 6am this morning and needed recharging by 10.30am! I have emailed Fitbit support but haven’t had a reply yet. Is this a common fault?
Best Answer05-22-2018 02:46
05-22-2018 02:46
Best Answer05-22-2018 08:26
05-22-2018 08:26
Mine too, about 18 months old and just recently in the last 3 weeks or so it's battery life has decreased markedly. Was toying with the idea of a Versa prior to this but if this is going to be what I can expect from Fitbit products, is an 18-month shelf life, ilI' consider other options. I've really liked my Fitbit & it's ecosystem. Hoping this is just software related & will be resolved with an update soon.
Best Answer05-22-2018 09:32
05-22-2018 09:32
Blaze is about 6 months old - daily use - but I am very cautious not to get it wet or harm it in any way. Now it holds a charge about 6 hours - from full charge to fully drained.
I am so disappointed and annoyed.
Best Answer05-22-2018 10:09
05-22-2018 10:09
Best Answer05-23-2018 10:25
05-23-2018 10:25
05-24-2018 06:55
05-24-2018 06:55
