11-14-2018
13:58
09:57
AlejandraFitbit
11-14-2018
13:58
09:57
AlejandraFitbit
Less than a year ago, I bought my Blaze and now the battery life is less than a day. Anyone else? What to do? I did clean all contacts between the watch and the charger. Turned off the heart tracker. Anyone?
Best Answer11-14-2018 15:30
11-14-2018 15:30
Hi, @KarenCook77! I can tell you that I have not had the same experience. I got my Blaze when they first came out (over 2 years ago) and it still holds a charge for days at a time. I don't use it all the time anymore, but I still use it several times a week for certain activities. Batteries are fickle things!
MakMak | Community Council
10:00
08:47
11-16-2018
10:00
08:47
It's great to see you here @KarenCook77 and @MakMak thanks for the input.
I appreciate all the efforts in trying to fix this issue and recommend taking a look at this post and follow the instructions provide there. After following those steps, test your Blaze.
Let me know the outcome. ![]()
Best Answer11-16-2018 12:04
11-16-2018 12:04
I am having the exact same battery drain issue on my Blaze...which is less than one year old. I will read the other posts for help. MS
