08-17-2016 11:28
08-17-2016 11:28
08-26-2017 15:21 - edited 08-26-2017 15:22
@Odyssey13 My wife doesn't normally leave the Blaze plugged in overnight. She likes to see her sleep patterns. She left it plugged in overnight to make sure it had a full charge. it's fully died a few times and she's charged it a few times since it began having the battery drain issue. We're still trying to do a full drain, but not sure how to do it. Pressing a button shows the low battery icon, but doesn't turn on. We use the charging cable it came in and plug it into the wall outlet. We'll leave it alone for a few more days and then try charging it up again. If it doesn't work, time for a new device.
Thanks for the suggestions.
08-26-2017 22:37
08-26-2017 22:37
Contact them first. Pretty good customer service. They may send u a new pebble (replacement tracker only). There is a defect with the battery. Mine arrived quickly and no problem with the replacement... yet anyway😊
Sent from my iPhone
08-26-2017 22:41
08-26-2017 22:41
(877) 623-4997
FITBIT CUSTOMERS SERVICE NUMBER
4pm - 9pm. Sry I 4got the time zone.
08-27-2017 09:56
08-27-2017 09:56
@Missi222 Will give them a call and see what they do out of warranty. Thanks for the suggestion.
08-27-2017 13:48
08-27-2017 13:48
09-04-2017 11:24
09-04-2017 11:24
Just FYI for anyone that's keeping up or looking at this thread. We called FitBit support and opened a case with them. They had us drain the Blaze, change usage settings to things that would drain the battery quicker be disabled and fully charge the Blaze again. They asked us to sync multiple times a day and try the Blaze again to monitor how long it would last. It only lasted 3 hours. We let them know the results and they reviewed the info from their end. They noted that it did not last long and said asked for purchase info on the Blaze. Based on that, they said it was out of warranty and offered a 25% discount on any new FitBit tracker. We're thinking about what we want to do. My wife and I have each had multiple FitBit devices fail on us (in and out of warranty). We've stuck with FitBit due to the features (while the devices were working) and customer support, but having many devices fail on us isn't reassuring.
09-04-2017 14:23
09-04-2017 14:23
Only 25%? That's a joke! My first one lasted 6 months so I'm not sure if this one will make it 6 months or not 🙄 But it's a no brainer 4 me... Apple Watch. They need to fix the battery issue instead of creating a new model. SMH
06-05-2018 13:04
06-05-2018 13:04
I have had my Blaze longer than a year, and it has been great! Recently, I started back to the gym and since the battery has been lasting shorter times. Today, it didn't even last till 3 after being charged fully before 6, when I took it off its charge and put it on Please tell me that I didn't spend this much for a watch that Fitbit will not bother with now. I need to have this thing working, and I was going to buy a new version in the future once a goal of mine has been reached, but not if the amount I spend isn't covered for battery issues and such in the future.
06-05-2018 13:05
06-05-2018 13:05
So is mine.
06-14-2018 05:14
06-14-2018 05:14
My blaze battery life span is only a couple of hours or so! I followed all the online help for resetting the battery and try to address the battery issue, no luck. Called the customer service, and they were absolutely of no help. They have records of all of your sync's, the last time you sync and at what time and what your battery life is. First time I called the customer service, they told me that they do not have a history of all my sync, so I would have to sync 5-6 times a day to have a record of my history. I already do that anyway, but they still insisted I do that for their records. Second phone call, I spoke to someone else, they said the same thing, but they had records for the past several days!. What the !!!!!!!!!!!!. After a lengthy discussion getting no where, I expedited to the manager, again still no help of what they can do for me. The only offer they give you is a discount on a new product!. REALLY!!, I purchased fitbit's for my family, spending hundreds of dollars and yet they want me to spend more MONEY!!!! NO WAY. Do better!!!! I am better off to purchase other products.
The Blaze product is a extremely poor quality product, it obviously hasn't gone through a Quality Control check for compliance. This product should be returned to product complaints to check on the quality of the product. I know the industry, and this is the process products go through in companies.
DO BETTER SERVICES TO YOUR CUSTOMERS
08-01-2018 19:42
08-01-2018 19:42
Can I replace fitbit battery
08-01-2018 19:43
08-01-2018 19:43
Do you plug to the wall?
Would like to know your IQ
No I plugged to my head
08-01-2018 22:47
08-01-2018 22:47
Hi @BobWest
The battery can't be replaced. The Zip is the only Fitbit with a battery that can be replaced - it's a button battery.
So, what's going on with your Blaze? Let us know.
08-02-2018 09:02
08-02-2018 09:02
08-02-2018 09:37
08-02-2018 09:37
Hi @Klp470
You'll get notice of every response to this thread since you are subscribed to it. If you no longer wish to get notification, just unsubscribe from the thread.
We do have a lot of older threads around here.
08-22-2018 13:26
08-22-2018 13:26
My blaze doesn't even last more than 4hrs anymore. I don't think I have the receipt for the store I bought it from (Best Buy-Canada). What options do I have??
08-22-2018 17:00
08-22-2018 17:00
Hi @CassG48
Get with customer support about this - click for contact options
Let us know how things go for you.
08-23-2018 15:48
08-23-2018 15:48
Every Blaze owner is going to have a battery issue, however, I am surprised that there are only 29 votes for the Replaceable Battery request in Fitbit Community -> Help Forums -> Feature Suggestions.
Not that any Blaze owner is going to ever purchase another Fitbit product, but voting for the Replaceable Battery would be a proactive, albeit futile gesture. Who knows this may send a huge message to Fitbit, but more likely to anyone thinking of purchasing a Fitbit product, that a replaceable battery is essential. Whether it is user or manufacturer replaceable.
Everyone that has googled "Blaze replacement battery" has seen the videos showing that the Blaze's batteries are in fact replaceable. One would think Fitbit would offer a Manufacturer Battery Replacement program for a reasonable fee, $25-$50. Keeping its customers happy and loyal. Then when Fitbit releases a compelling new product (sorry the Ionic and Versa are not), loyal customers would willingly upgrade. For example, how many Blaze owners previously owned a Charge HR?
08-23-2018 18:12
08-23-2018 18:12
Actually @SunsetRunner due to the nature of batteries, and device that has a baby tery will at some point in time have a battery issue. A typical car battery has a life of 3 - 5 years. Your Fitbit battery is a lot smaller and more susceptible to internal damage.
08-23-2018 19:29
08-23-2018 19:29
@Rich_Laue wrote:Actually @SunsetRunner due to the nature of batteries, and device that has a baby tery will at some point in time have a battery issue. A typical car battery has a life of 3 - 5 years. Your Fitbit battery is a lot smaller and more susceptible to internal damage.
Dahh!!!! No kidding. That is the point! The batteries die over time and should be replaceable. Let progress be the tool of obsolescences, not a non-replaceable battery.
