12-28-2019 05:44
12-28-2019 05:44
The iPhone app had a battery with a slash through it and wouldn’t update. When I plugged in the Fitbit the battery indicated 40-50%. I checked and the app updated-synced. I also have the prolonged vibration when receiving a incoming call. I think your app needs a better interface. I had a basis for years till it was discontinued. I believe it was superior. I have been using the Fitbit blaze for many years.
Best Answer12-29-2019 15:00
12-29-2019 15:00
Your app does not look at the tracker for the battery level, but gets it off of the server. The server is updated with a sync.
