03-09-2016
07:37
20:22
DavideFitbit
03-09-2016
07:37
20:22
DavideFitbit
I just got my blaze last night. I fully charged it and now at 930am the battery is at half life. I thought it's suppose to last multiple days? I turned off the quick view and heart rate monitor is on auto. Does the batteries on the blaze only last one day?? Need the communities help. Thank you
Best Answer03-27-2016 17:06
03-27-2016 17:06
04-08-2016 20:07
04-08-2016 20:07
Same here ...so frustrating!
Best Answer05-30-2016 08:13
05-30-2016 08:13
mine last only one day also grrr they said 4 to 5 day but it does not
Best Answer06-01-2016 20:31
06-01-2016 20:31
Best Answer06-09-2016 22:18
06-09-2016 22:18
Mine is doing the same thing. Just started this week. I called customer support and they said to turn everything off. Sync, notifications, alarms (which I didnt have on) charge the thing, and they are going to be watching it for a few days. Stalking me. It has been shutting off completely after ~ two days. When I plugged it in to recharge, I got the email that said my battery was low!! So, yes, a complete shut down! No notice. I relate that to a computer error, or crash. Something is wrong. I was an "early adopter" and pre ordered. Could be a bad idea.
Best Answer06-10-2016 04:27
06-10-2016 04:27
Best Answer06-10-2016 05:04
06-10-2016 05:04
Best Answer06-10-2016 10:40
06-10-2016 10:40
How long did you have to wait to get your replacement? I am having trouble with blood pressure and heart rate. Trying to work up to long extensive hikes after breast cancer and I REALLY need this for my health. I cannot afford to be on my uphill climbs and have the thing quit.
Best Answer06-10-2016 10:50
06-10-2016 10:50
Best Answer06-10-2016 11:06
06-10-2016 11:06
She said nothing about my ability to track the app that they have. Any information you can give me about that?
Also, I was a bit miffed that they made me turn off the applications that I use daily. She stated these could be draining the battery. If they are, then the product is not working as it should. She was a bit difficult to understand over the phone (a strong accent). I should be able to use all that the unit was designed for... otherwise I will look elsewhere. I get the impression that I am troubleshooting a unit for them after purchasing it just 3 months ago. Did you have to go through this trouble shooting process?
My daughter is on her 4th or 5th Fitbit with a few replacements, no questions asked. The reason why I did not worry about being an early adopter.
Thank you for your prompt reply.
Best Answer06-11-2016 06:54
06-11-2016 06:54
Best Answer07-25-2016 19:11
07-25-2016 19:11
Best Answer07-25-2016 19:55
07-25-2016 19:55
Best Answer10-23-2016 17:16
10-23-2016 17:16
Best Answer03-08-2017 03:45
03-08-2017 03:45
Same! Did you end up fixing it?
