09-05-2019
19:26
10:12
09-05-2019
19:26
10:12
Every time i charge my blaze then use it...my watch dies very very quickly
09-09-2019 10:14 - edited 09-09-2019 10:15
Hi there @NikkiBaby91, welcome to the Community Forums. I'm sorry for the late response. I'll be glad to help.
Please take a look at the help article Can I extend my Fitbit device's battery life? and follow the tips and recommendations provided there.
We recommend to charge your trackers via the USB port over a wall adapter. However, it is also possible to charge your Fitbit tracker with a UL certified wall adapter. What may actually cause damage to the tracker's battery (either on a computer or a wall adapter) is the charging time, which if excessive over time may damage the battery and therefore cause quick battery drain or prevent the tracker from charging at all.
Tips to best charge Fitbit trackers are:
For charging purposes, your charging cable can be plugged into any USB power source, including but not limited to:
Give this a go and let me know the outcome, I'll be around.
09-09-2019 16:08
09-09-2019 16:08
I have been having the same problem. My battery is lasting no longer than a day and a half. I have tried your tips and it's made no difference
09-09-2019 18:18
09-09-2019 18:18
Mine just started doing the same thing. Today it started out a full charge and died after 5 hours. I turned notifications off right after charging it. Still ran down quickly. Can the batteries be replaced? I work in healthcare and rely on my Blaze. Please help
09-09-2019 21:57
09-09-2019 21:57
Mine started draining quickly yesterday. I usually charge mine on Sundays and Wednesday’s. Now it all of the sudden barely lasts half a day.
09-10-2019 14:27
09-10-2019 14:27
Hi there @Wendijo, @EchoLady, and @B3rtiebassett, welcome on board. Thanks for following the tips and recommendations provided above.
Since none of the steps you tried have worked, I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon!
Let me know if there's anything else I may do to assist you with.
09-12-2019 16:26
09-12-2019 16:26
I’ve been having the same problem for a couple months. Very frustrating when it dies after a couple hours. I’ve always used the charger it can with and tried all the suggestions mentioned. And have never charged more then a couple hours as I’ve worn it as much as possible.
09-13-2019 17:34
09-13-2019 17:34
09-14-2019 09:13
09-14-2019 09:13
I have completed all the required steps and my blaze still will not hold a charge.
09-14-2019 14:48
09-14-2019 14:48
09-14-2019 15:03
09-14-2019 15:03
Thank you!
09-14-2019 17:04
09-14-2019 17:04
I've had my Blaze for about 1.5 years and the battery doesn't last for more than a day now. The last time it happened, cleaning and restarting helped but now it doesn't. I tried shutting it down, unpairing and then re-pairing and neither helped.
09-14-2019 17:07
09-14-2019 17:07
09-15-2019 21:11
09-15-2019 21:11
09-15-2019 21:13
09-15-2019 21:13
09-15-2019 23:07
09-15-2019 23:07
09-23-2019 08:36
09-23-2019 08:36
@B3rtiebassett it's great to see you in our Fitbit Community. By the way, I'm sorry for the late response.
I was able to get in touch with our Support team and since your Versa is still experiencing the same issue, I was able to get in touch with our Support team and was told that they sent you an email with some instructions.
Please reply to the last email they sent you so they can investigate further and assist you accordingly.
I'll be around if any question arises.
09-23-2019 08:40
09-23-2019 08:40
09-23-2019 08:45
09-23-2019 08:45
@B3rtiebassett What were the suggestions? I'm curious if there's anything I haven't tried already. I've stopped wearing my Fitbit as the charge doesn't even last the whole day anymore. Thanks!!
09-23-2019 09:08
09-23-2019 09:08
