09-11-2019
18:43
14:21
09-11-2019
18:43
14:21
Started 9-8-19 woke up to dead battery. Having to charge every 2 hours. Done all the recommended things no change. Is there any truth that the update caused this? I can’t afford a new tracker. Very unhappy
Hi there @Chris96, welcome to the Community Forums. I totally understand how you feel. Rest assured that I will do my best to help you.
Thanks for taking the time to troubleshoot your Blaze's battery prior to contacting us. Please confirm that you've followed the tips and recommendations provided in the help article: Can I extend my Fitbit device's battery life?
We recommend to charge your trackers via the USB port over a wall adapter. However, it is also possible to charge your Fitbit tracker with a UL certified wall adapter. What may actually cause damage to the tracker's battery (either on a computer or a wall adapter) is the charging time, which if excessive over time may damage the battery and therefore cause quick battery drain or prevent the tracker from charging at all.
Tips to best charge Fitbit trackers are:
For charging purposes, your charging cable can be plugged into any USB power source, including but not limited to:
Best AnswerMine has been doing the same thing. I dont have to charge every 2 hours but it used to last me like 3 to 4 days without charging it. Now I'm lucky if I get through a day without it saying low battery.
Best AnswerI have had my Blaze for less than 12 months and the battery needs to be charged daily now since August, I have e-mailed Fitbit a number of weeks ago regarding this and got no response. I have also tried the troubleshoot options, which haven't helped. This was a replacement watch for the Charge 2 I had before it, it was just over a year old when it decided to stop working. I was very happy with the Blaze but I am now getting a very bad impression on Fitbit products due to the short life span of expensive watches.
Best AnswerI am having the same problem. I use the silent alarm to wake me up for the gym so as not to wake up my wife. I woke up in the middle of the night to see that the battery was down to the red. So, I got up and charged it at around 2:30am. It's now 3:14pm and the battery is back in the red already. I am NOT happy.
