Blaze battery is dying
My blaze battery is not even lasting a day is anyone else having this problem?  I used to get about 4 days before I had to recharge it now I can't even get through a full work day.
4 REPLIES 4
My Blaze started just this week, having to be charged daily, in less than 24 hour increments.  I wonder if this is a common happening.  The problem is that my Blaze is not even a year old yet!
Hey @nursngrl04,
Im sorry to hear about your Fitbit Blaze Battery problem.
Here are some tips on how to maximise your Fitbit Blazes Battery Life:
https://community.fitbit.com/t5/Blaze/Tips-to-maximize-the-battery-life-of-your-Blaze/m-p/1263819#M9...
If you have already tried all of those troubleshoot methods and you are unhappy with the battery life you are receiving, go and contact Fitbit's support team. They can give you a more detailed reason as to why your device is losing battery rapidly.
If non of these methods work and Fitbit's support team cannot solve your issue, check to see if your Fitbit is within the Warranty period. If it is, Fitbit may be able to replace your tracker!
Thanks!
What smartphone do you use?
It's great to welcome you @nursngrl04@Sparklie12 great to see you around, @Daniel_Wescombe and @Robert1988 thanks for stopping by.
If you are experiencing battery inconveniences with your trackers, I recommend taking a look at this post and follow the instructions provided there.
I hope this helps, let me know the outcome. Woman Happy
