09-05-2017 05:37
09-05-2017 05:37
Had the blaze a little over a year. Battery Is drained and dead within hours. Disappointed and very unhappy. Will be switching to an Apple product
Best Answer09-05-2017 05:39
09-05-2017 05:39
Do you happen to use an S8 / S8+ ?
I only ask because if you do you may be affected by this known bug causing battery drain on the Blaze:
https://community.fitbit.com/t5/Blaze/Battery-drain-Samsung-Galaxy-S8-S8/m-p/1963139#M65290
09-08-2017 06:03
09-08-2017 06:03
Welcome to the Forums @unhappywiththis and @SteveH thanks for stopping by.
I would like to know if you keep having issues with your Blaze battery life? If you do, I recommend taking a look at this post and follow the instructions provided there.
Let me know how it goes. ![]()
