01-28-2018 22:53
01-28-2018 22:53
I just bought the blaze over Christmas and set up my blaze 10 days ago.
Im stunned to find out that i have to charge it everyday as the batter barely lasts for 24 hours.
My notifications is always off, brightness is dim and i havent really tracked exercises, i rarely touch the screen and its a brand new Blaze!!! I spent over $200 for a watch that is supposed to last 5 days and now i have to charge it every night. I cant imagine how it will last after 6 months of use.
Thats absurd.
Best Answer01-29-2018 04:29 - edited 01-29-2018 04:29
A warm welcome to the Community @Moe_beast.
Thanks for troubleshooting this by yourself. If you are having issues with your Blaze battery life, I recommend taking a look at this post and follow the instructions provided there.
I hope this helps, let me know how it goes. ![]()
Best Answer02-01-2018 03:55
02-01-2018 03:55
Hello, I had similar trouble, I charging my device always using the power adapter( like cellphone power adapter) by wall outlet and 3 days ago my device stopped charger and Now only get charger using Computer USB port and the battery life its better than charging by wall outlet.
Hugs and cheers from Brazil
Tiago
Best Answer02-01-2018 03:59
02-01-2018 03:59
It's great to see you around @TIAGOBARROS.
I would like to know if you have tried the instructions provided in my previous post? If you haven't, I recommend taking a look at it and follow the tips provided.
Let me know how it goes. ![]()
Best Answer02-01-2018 04:09
02-01-2018 04:09
Greetings Alejandra; Yes I cleaned using Isopropyl Alcohol the same product that I use to clean my computer parts like motherboard, graphics cards, etc. but did not works when charged using wall outlet and only when plugged in my computer USB port I got charge my device; Before tried contact Fitbit by chat support. But now everything OK. I don't know if Blaze or another fitbit devices comes with this " problem" when use the wall outlet to charge.
Thx again
Tiago
Best Answer02-02-2018 03:27
02-02-2018 03:27
It's great to hear that you get to charged your tracker in your computer @TIAGOBARROS. If you need anything else, do not hesitate in posting it.
Happy stepping! ![]()
