07-23-2018
14:43
11:19
FerdinandFitbit
07-23-2018
14:43
11:19
FerdinandFitbit
My Fitbit blaze is not even a year old and its battery life has gone from 3 to 4 days to 1 to 2 days. Can you help with this issue?
Best Answer07-24-2018 11:20
07-24-2018 11:20
Hi there @Kimclym. Good to see you in the Fitbit Community Forums! 🙂
I'm sorry to hear you're having problems with the battery on your Blaze not lasting as it should 😕
I can recommend putting your tracker to charge and once it's fully charged, take it off the charger and put it on. Sync it and use it as you would normally do. Make sure to sync it frequently after this (every one or two hours at least) so that the battery levels are recorded on the app logs and once the battery dies, let me know so that I can take a closer look and then we can move forward with other options to get you back on track.
I'll be looking forward for your reply!
