01-22-2016 21:30
01-22-2016 21:30
03-06-2017 07:20
03-06-2017 07:20
Seems like you would still get your distance as long as you are using your gps on your phone. And if you use the estimate of approx 2000 steps per mile you can assume you would have walked that amount if you were walking and then manually add that to your blaze. Idk I like to see my steps but really you know if you worked out whether it be biking or something else so it still counts.
Best Answer03-06-2017 12:51
03-06-2017 12:51
Best Answer04-29-2017 05:46
04-29-2017 05:46
I have a blaze and got a map after my cycling.
Best Answer04-29-2017 06:30
04-29-2017 06:30
Hi Erick,
I can't seem to figure out how to turn on the gps for tracking my biking miles. It has it for my runs so I am pretty confused. Please help
Best Answer04-30-2017 01:04
04-30-2017 01:04
04-30-2017 01:04
Best Answer05-12-2017 04:25
05-12-2017 04:25
I have the fitbit app on my phone and I have my phone connected to the fitbit blaze using Bluetooth, but when I start a ride it isn't recording the mileage. Is there a step I'm missing?
Thanks,
Best Answer05-12-2017 05:03
05-12-2017 05:03
05-13-2017 10:37
05-13-2017 10:37
Mext tome @phatkicker check the phone icon on the Blaze, if it is red the the tracker lost the gps connection.
Has the phone been restarted yet?
Do you have Fitbit Notifications running? Since your asking about a phone, can we be enlightened as to thr model?
Best Answer05-13-2017 12:51
05-13-2017 12:51
Best Answer05-14-2017 17:05
05-14-2017 17:05
@Shaylie on your Blaze go to the.Bike screen. Tap the sett8ngs gear, turn on GPS. Now start tye recording.
Best Answer05-15-2017 22:25
05-15-2017 22:25
Best Answer05-21-2017 12:09
05-21-2017 12:09
I know in the past I could choose bicycling and my GPS would come up. Now it doesn't. Was there an update that change that
Best Answer06-27-2017 09:14
06-27-2017 09:14
I do not see any option under exercise for hiking or yoga as you had mentioned. Also how to I use the GPS Connect? Just got my Blaze and trying to figure things out
Best Answer06-28-2017 00:29
06-28-2017 00:29
@cmurph127 from your dashboard, click or tap on the picture of your tracker found in the top right corner, niw ooen the Exercise shortcuts, remove what you don't want, add what you want, arrange them in the order you want. Exit and wait for tye tracker to sync.
For tye GPS start up an exercise like walk, run, hike, or bike, the Blaze should connect to the phones gps.
Best Answer10-01-2017 05:04
10-01-2017 05:04
Hi, does anyone know how long the battery last when going fir very long cycling trips? ie: 7 hours cycling uding gps
Best Answer10-01-2017 05:07
10-01-2017 05:07
Hi, does anyone know how long the battery last when going for very long cycling trips? ie: 7 hours cycling using gps, thanks!
Best Answer10-01-2017 05:51
10-01-2017 05:51
Best Answer10-11-2017 03:21
10-11-2017 03:21
On my blaze tracking i can only choose walk run hike. How did u get bike. I mainly ride and its driving me crazy
Best Answer10-11-2017 04:28
10-11-2017 04:28
@Huddo1903 - Make sure to start the exercise from the Blaze (not your phone, which can only start and track the three activities you mentioned). If biking is not on the list of exercises you can choose from on your Blaze, you will have to add it in settings on your phone or computer app then sync to get it on the list of available exercises on the Blaze.
Scott | Baltimore MD
