11-19-2017 02:25
11-19-2017 02:25
Hi, my blaze has a blank screen. It is fully charged and the green lights are flashing. I have tried restarting (holding left and bottom right buttons), the Fitbit logo appears but then it goes blank again.
04-13-2019 04:23
04-13-2019 04:23
Just 2 days ago, I experienced the same black screen issue and attempted to fix by rebooting but no luck. I don't think it's still under warranty (I'm checking into this). Is a warranty replacement an only option? Or is there an OS fix?
Best Answer06-03-2019 16:50
06-03-2019 16:50
So what is the solution - I did drop mine on the floor - and although the green lights on the back are flashing I can't seem to get the screen again..........thank you.
Best Answer06-04-2019 05:10
06-04-2019 05:10
Best Answer06-04-2019 06:57
06-04-2019 06:57
My Blaze is fully charged but the face won't light up and only one of the green lights is flashing.
The battery only lasts for about 2-4 hours. It still tracks on the app on my phone, but I can't see the time, steps or anything on the Blaze.
Best Answer08-15-2019 11:53
08-15-2019 11:53
Hello, I have the same problem with my fitbit blaze, First I got a black screen, then I tried to reset with the 2-button reset, It worked since I was able to get the logo on screen again but after that the watch turned off and now the 2-button reset is not working at all, The watch is charged but I can see the screen anymore. Please help me to have this escalated
Best Regards
Best Answer08-15-2019 22:38
08-15-2019 22:38
08-16-2019 09:02
08-16-2019 09:02
Best Answer09-30-2021 05:26
09-30-2021 05:26
I know this is a very old thread, but I had the same problem and found this thread by Googling my issue, so I'm posting the solution that worked for me: I had this happen (blank screen, green buttons flashing) and the restart (holding left and bottom buttons) didn't help. Since the green lights were flashing, I knew it wasn't completely dead. I inserted a paperclip into the small hole on the back of the Blaze for 15 seconds or so (which is how I had to reset my old Fitbit Flex), then tried the reset again (holding left and bottom buttons). The Blaze came back to life. Good luck!
