06-03-2018
13:05
04:46
AlejandraFitbit
06-03-2018
13:05
04:46
AlejandraFitbit
It won’t restart despite holding the two buttons down, it won’t re charge, basically the screen is just blank. All the data is correctly updated on the app but that is next to useless if the watch screen is blank. It’s only 8 months old and I hardly use it, assume these are bug ridden. A lot of money for poor technology.
06-03-2018 17:46
06-03-2018 17:46
That means that you need to charge it or put a new battery in it
06-04-2018 04:47
06-04-2018 04:47
A warm welcome to the Community @Jonesjck and @loveemandtrey thanks for stopping by.
I appreciate the efforts in trying to fix this issue. Please confirm these are the steps you did in order to restart your Blaze:
After this, I recommend trying to sync your tracker. If this doesn't work, let me know.
06-04-2018 14:50
06-04-2018 14:50
So this doesn’t work, it just stays as a blank screen (like I said in my original post) The only thing I think is that the charger doesn’t work so there is no life in the battery. I’m on my second charger because the one that came with the watch stopped working shortly after I set it up. I bought another one but I can’t tell if that’s the problem . I don’t think I should have to pay out for a third charger on a hunch that that’s the problem , when it could be something else .
