Blaze charger is loose
ANSWERED
Just got a fitbit blaze two days ago. The charger I received with the Blaze seems to be slightly loose - the blaze can move around inside the box and sometimes stops charging if it get bumped or moved as the pins no longer line up. I was wondering if anyone else had this issue or if I should try to get a replacement charger.
1 BEST ANSWER
Accepted Solutions
If the device moves to the point it won't charge, I would email support and tell them of the issue.  They will probably send you a new charger.
3 REPLIES 3
These chargers aren't made very well, I'm going on my fourth replacement.
What I did was to clean with a wooden toothpick the corners of both the Fitbit Blaze and the chargers. After that, charging is working smoothly. I noticed that a slight misalignment would stop the charging, and cleaning the edges help in the Blaze fitting snugly in the charger.
