Blaze compatibility with samsung avant
will blaze ever be compatible to samsung avant.  just purchased a blaze to motivate me to be active (big joke).  imagine how dissapointed i was to find that my phonen(samsung avant) is not compatible.  how hard is t to add?  i'd hate to have to return it, or worse yet, upgrade to an expensive phone just so I can use it.  HELP!!
3 REPLIES 3
You can set it up on the computer until its added
http://help.fitbit.com/articles/en_US/Help_article/1873
You should really check the compatibility before buying
Community Council Member
Wendy | CA | Moto G6 Android
i was able to sync today. fingers crossed that it will continue working.
the first piece of information you provided is appreciated.
the 2nd piece i found condescending and unnecessary. Pretty sure I figured
that out, hence the post to your website. There should be a large
disclaimer on your packaging that states that this product may not work
with your device. But thanks, I will definitely research any additional
products that i contemplate purchasing from this company.
A warm welcome to the Forums @SunsetRunner and @WendyB thanks for stopping by.
Our team is testing the compatibility of several trackers, your patience will be much appreciated. I recommend keeping an eye on our list of compatible mobile devices for any update and in the meantime, as recommended, you can sync your tracker with a computer or a compatible phone.
Catch you later. Woman Happy
