02-01-2021 07:46
02-01-2021 07:46
My Blaze died yesterday and I put it on the charger when I got home. The screen didn't show the charging icon when I plugged it in, and after letting it charge all night, it won't even turn on. My app says the battery is dead, and I checked to make sure that the charger was connected properly. What could the problem be??
Best Answer02-02-2021 20:39
02-02-2021 20:39
Hi @Meg.518 that's what happened to me when my Blaze died. All I can suggest is that you keep trying to charge and restart it, but it does seem like it's dead. You can double check that all connectors are cleaned, but it sounds exactly what mine did.
