11-21-2017
17:35
06:58
AlejandraFitbit
11-21-2017
17:35
06:58
AlejandraFitbit
My Fitbit Blaze display is always on and everyday, I have to charge it. There is any figuration that I have to change or it might be some problem with?
Best Answer11-21-2017 18:16
11-21-2017 18:16
@guitoronto do you know how many people would love to have your Fitbit? We have hundreds of requests to keep the display on, even if it needs charging every day. Why not auction it off, ok just kidding about the auction.
Yes I can see how this could be a problem, let's try a restart ok try 3 restarts.
11-22-2017 07:35
11-22-2017 07:35
Hey there @guitoronto, welcome to the Forums and @Rich_Laue thanks for stopping by.
I would like to know if the recommendation suggested worked for you or if you still having issues? If you do, you can also try to shutdown your tracker by swiping to settings and tap/confirm the shutdown. If the restart procedure didn't work for the battery issue, you can take a look at this post and follow the instructions provided there.
Let me know the outcome. ![]()
Best Answer11-22-2017 13:08
11-22-2017 13:08
I restarted 3 times yesterday and it is working better but last night time I woke up and the display light was on and for a long period it didn't go off. sometimes display goes off . I think it should have a problem.
