08-17-2017
15:23
04:59
AlejandraFitbit
08-17-2017
15:23
04:59
AlejandraFitbit
Hi I got problem. My Blaze stop working only green light flashing. After I put in to the charger is showing some strange numbers, when takes out is only back light flashing. Any suggestion or solution for that?
Best AnswerHi I got problem. My Blaze stop working only green light flashing. After I put in to the charger is showing some strange numbers, when takes out is only back light flashing. Anny suggestion or solution for that.![]()
It's great to see you around @jurgen-gb and @Fabes67 welcome to the Community, thanks for troubleshooting this by yourself.
If your Blaze display are not working, I recommend restarting your tracker. Also, could you please provide some pictures of what you are seeing on the display?
Hope to hear from you soon. ![]()
Best AnswerHi. But the problem is blaze is not responding at all for any button also is impossible to do anything.
That is on my display. Hope that will help to understand that problem.
Thank you very much for the attachment @jurgen-gb. At this point, I recommend keeping an eye on your inbox for further instructions.
See you around. ![]()
