04-11-2016 12:18
04-11-2016 12:18
My stride is accurate. It almost perfectly counts my steps, however the distance is off. I consistantly get over 10,000 steps, but I rarely have over 5 miles unless I reach 13,000 - 15,000 steps. I finally realized that it was the auto-recognized walk and run that were causing the inaccuracy. It only calculates distance if I use the Excercise option for Walk. I almost always forget to select that option, and it autocalculates Walk so I am always under on my distance. Is this something that will be fixed in a firmware update? I love the auto-recognize option, but it is not great if the distance is not calculated.
I also have an intermittent problem with the screens getting stuck. I have to tap hard 5 or 6 times to open the Countdown screen, and also on some of the exercises. If I reset the Blaze, if fixes the problem, but only temporarily. It is a headache when I am ready to start the exercise and tapping won't open the screen. Is this something that will be fixed with the new update?
04-28-2016 14:31
04-28-2016 14:31
