Blaze does not keep track of time when it is switched off?
Hello,
Is this a feature or something is wrong. I switch off my blaze when i go to sleep and when i switch it back on in the morning it shows the time from the moment i swithed it off. And it gets correct time only after a sync it with my phone. Surge was actually keeping time when it was off.
thank!
3 REPLIES 3
@kidr  This is now expected behavior.  (After the last update). It was mentioned that now if your Blaze shuts off - either due to low battery or manual shutdown - you will have to sync it to update the time.
Kelly | Oklahoma
Alta HR, Blaze, Flex 2, Charge 2, Charge, and Aria * IPhone 7+
So before update it was working properly?:) I wonder if there is any specific reason why it was changed, was the last update done by aliens from Orion constalation:)? I had a habbit to switch off my surge before going to bed, i did not wear it through the night, i guess this was saving some battery at least:)
There is no need to switch it off. It doesn't save much battery because HR ist siwtched off a few seconds after lying on the table.
