08-28-2017
03:34
20:07
DavideFitbit
08-28-2017
03:34
20:07
DavideFitbit
My Fitbit Blaze does not show the mileage when I go for a cycle, only the time. If I go for a run my blaze will show the distance and the time. What do I need to do so I can see the distance on my blaze at the end of my cycle?
Best Answer08-28-2017 12:19
08-28-2017 12:19
Sorry @BelCane, I'm not sure of which mode your using to record the bike ride.
You will need to have the phone with you, and use the Bike mode with connected GPS. When you get back and sync you will also see a map of your ride.
Best Answer08-28-2017 13:10
08-28-2017 13:10
