01-12-2018 07:54
01-12-2018 07:54
Since the blaze is bigger, I have decided not to wear all night and use this time to charge, etc. I quickly discovered the pulsing green lights don't really work well to leave on in a dark room. The only way I have found to turn off overnight is to scroll all the way to settings and then all the way to bottom to turn off. This process takes about 8 seconds which is not very handy. Would seem like there is a better way that could easily be done in more like 3 seconds. Please let me know if there is or whether this would need to be an improvement. Being able to swipe left to go get to settings or holding a button continuously for 2-3 seconds would be options I can think of quickly.
Best Answer01-12-2018 10:48
01-12-2018 10:48
I have had a little look around, it seems that the only way to turn off the blaze is to like you said
There doesn't seem to be a quicker way of turning the device off.
Best Answer01-18-2018 13:50
01-18-2018 13:50
I find it easier to leave the Blaze turned on. Turning it off at night requires a sync immediately after turning it back on in the morning, who has time for that. Another problem is once in awhile you will find yesterday steps do not reset at midnight.
Best Answer01-18-2018 18:56
01-18-2018 18:56
After taking off the blaze the green lights will turn off on their own after about 30 secs so there is no need to turn off the actual device.
