Blaze is not charging and not tracking data
My Blaze did not even last two years...is anyone else as disappointed in their fitbit as I am? Just when you come to depend on it...it won't hold a charge, it won't register my heart rate...I am completely disillusioned with this whole fitbit line...in my world, I paid a lot of money for it and the fact that it last that long is crazy...
2 REPLIES 2
Thank you for reaching out to the Community @marymore. I really appreciate the time you've taken to report the issues with your Blaze. Sorry for the delayed response.
I'll be glad to give you a hand with this. First of all, let's try a couple of steps to make your Blaze to charge again:
I'd suggest to clean the contacts of your Blaze. These contacts can become obstructed by microscopic dirt or debris that prevents them from making a good connection to the charger. Use a toothpick or toothbrush to clean the charging contacts, do not scrape them with anything metal because this may damage the plating and result in corrosion.
Please try to restart your it once again. How are you changing your Fitbit? We recommend plugging your charging cable into a USB port on your computer or other low-energy device. If necessary, you can use a UL-certified USB wall charger. Don't use a USB hub or battery pack to charge, and only use the charging cable that came with your tracker. Did you have issues before with the charging cable?
Please take a look of these recommendations to charge your Fitbit too. Once your Blaze is charging, you can check this article: Why don't I see my heart rate on my Fitbit device?
Let's give it a try and please keep me posted.
I don’t have any contacts in it...and if I do, I don’t how to clean them
out. I don’t use it for that. I even turned off my notifications. I just
took a soft bristle toothbrush to it and it’s now charging ( it wouldn’t do
that before)...I’ll let you know how it goes!
I cannot thank you enough for reaching out! I gave up on it.
Cheers,
Mary
