10-06-2017
03:46
05:03
AlejandraFitbit
10-06-2017
03:46
05:03
AlejandraFitbit
Hi, my Blaze Fitbit will not pair with my Bluetooth, I have tried all your troubleshooting and nothing has helped.
10-06-2017 05:24
10-06-2017 05:24
Hello @Elizabeth15273, does your Blaze sync?
You say that you can not pair tye Blaze, but havent explained at what step the pairing process fails or if tyere is an error given.
The thing is, the user can not pair the Fitbit tracker to the phone, this is tye job of the app.
10-06-2017 05:28
10-06-2017 05:28
10-06-2017 06:00
10-06-2017 06:00
Does it say " Blaze won't pair " or does it say "Pairing rejected by the Blaze"?
Does your tracker sync to your fitbit account or does it need to be setup?
I'll repeat a user can not pair the tracker to the phone, this action will be rejected every time.
Best Answer10-06-2017 07:17
10-06-2017 07:17
Hi I registered the app and confirmed the email It says pairing rejected by blaze . On my Bluetooth on my Android phone I can't get anything on the watch all it says is fitbit.com/set so I am stumped
Best Answer10-08-2017 05:05
10-08-2017 05:05
It's great to welcome you @Elizabeth15273, thanks for troubleshooting this by yourself and @Rich_Laue for stopping by.
I would like to know if you keep having issues setting up your Blaze? If you do, I recommend restarting the tracker and confirm you are doing the following to set it up from your Fitbit app:
Also, if you can provide me with some photos of the error you are seeing would be great.
Hope to hear from you soon. ![]()
