Blaze losing battery life (and my fix)
I've had my Blaze about a year, and I've noticed that every few months it starts to lose it's battery life. Normal has always been about 5 days or so. It starts getting down to 1 1/2 to 2 days of battery life when I have to "fix" it.
Here's what I've done to fix it, and it works every time (brings battery life back to the full 5ish days).
When the battery dies, press the "back" button, and it will either start up the Blaze for a minute, and die again, or it will just show the empty battery symbol for a few seconds and turn off. If it shows the battery, just keep repeating that until it won't turn the screen on anymore. It can take an hour of on/off cycles to totally discharge the battery. After it stops turning on, wait a few minutes, and try again a few times. Totally discharge it. Then, charge the battery for an hour or so. Issue solved for a few months.
It seems like every time the battery is charged while not being 100% discharged, it loses a bit of it's capacity. Or battery memory, or whatever some people call it. This seems to take care of it for a bit.
I don't know if this is fixable via firmware update, but it's pretty annoying losing a day or 2 of stats to "fix" this myself.
2 REPLIES 2
Welcome to the forums!
Thanks for this info! I will keep it handy in case I have this problem
Hope to see you around the forums! Join in on the discussions forums!
Community Council Member
Wendy | CA | Moto G6 Android
It's great to welcome you @shouck and @WendyB thanks for stopping by.
I appreciate the steps you shared which are the ones you followed to solved your battery inconvenience. I know there are a lot people that will find your post really helpful. As recommended by our friend @WendyB, I invite you to visit our Be Inspired board in which you can talk about your experiencing and provide tips to our Community.
Catch you later. Woman Happy
