09-25-2017 12:52
09-25-2017 12:52
I walked and then separately ran the same distance using connected GPS. The run measured it as 2.9 miles whilst the walk measured it as 3.22 miles. This is a regular feature. I have tried setting the stride length manually for walking and running and also used the automatic function but this difference seems to prevail. Please can anyone explain why this happens?
Best Answer09-25-2017 13:19
09-25-2017 13:19
So which distance is correct?
Best Answer09-26-2017 03:14
09-26-2017 03:14
Hi,
Running distance is the accurate measurement.
