Blaze not being accurate
ANSWERED
My Blaze step counter seems to give me different results that my app called Runtastic Pro. Many ideas as to why I get different readings on my mileage?
1 BEST ANSWER
Accepted Solutions
It's great to welcome you @LakotaBlaze and @Rich_Laue thanks for stopping by.
If you are seeing that your tracker is not being accurate, I recommend restarting it and make sure that your stride length information is correct. After this please test the Blaze.
Let me know the outcome. Woman Happy
3 REPLIES 3
Not really @LakotaBlaze what 'em type of stats are we referring to? Which way did you record your exercise and what type of exercise where you doing?
Runtastic pro looks like that it uses GPS, where you using GPS with the Blaze?
Thanks for respond.
The Runtastic Pro is off distance wise about half mile. The run time is the same but it’s records the run in shorter distance than my Fitbit does.
