06-27-2019
00:37
17:04
LizzyFitbit
06-27-2019
00:37
17:04
LizzyFitbit
1. The battery is empty and unable to charge.
2. The green light is not being emmited.
3. The port has been changed to no effect.
4. HR switched off and restarted but unable to sync as battery empty sign is displayed.
06-28-2019 17:02
06-28-2019 17:02
Hi @drsanjeev, welcome to the Community Forums!
Thanks for sharing detailed information about your Blaze, and the steps that you've done. You did a great job! Since your device isn't fully charging, this should be the reason why the heart rate stopped working. While you've tried restarting the heart rate functions and using a different USB port, I'd recommend to try the following steps:
Give it a try and let me know how it goes.
06-29-2019 06:51
06-29-2019 06:51
The same thing just started to happen to me yesterday. The green backlight is constantly on and the batter will not hold a charge.
06-30-2019 11:08
06-30-2019 11:08
06-30-2019 14:52
06-30-2019 14:52
Hi @Tombert65, welcome to the Community. @drsanjeev, it's nice to see you around.
@Tombert65, thanks for bringing this to my attention, and I'm sorry for the issues experienced with your Blaze. I've checked with our Support Team and apparently they already took your case under their wings. I'd recommend to continue working with our team, so they can help you out.
@drsanjeev, thanks for getting back. Just to confirm, have you tried the steps posted above?
Keep me posted.
