Blaze not charging even after 3 days of trying
I was excited to get my fitbit blaze, but really sad to see the poor quality of charger. Even after trying so many times from last 3 days, the same is not charging. Have connected to laptop, other charging points but no battery icon.
5 REPLIES 5
Sounds like a defective charger or could be the Fitbit as well.
If bought else where take it back and exchange it
If bought here contact support
http://help.fitbit.com/?cu=1
Community Council Member
Wendy | CA | Moto G6 Android
My first thought is, where you able to set the Blaze up? If the BlAze has a message on the screen that says www.fitbit.com then there will not be any charging indication and only a slight buzz when connecting it up.
My tracker would not charge when I first got it. I tried restarting it 3 times, and then put it back in the charger. I came back after a couple of hours and it was charging. Try and see if it works! Good luck.
My Blaze will show as fully charged but as soon as I take it out of the charger and put it in the band it shows battery low and will not work.
@Tmwolfe take a look at this post.. Then follow @WendyB's advice above, if your still having problems.
