10-22-2016 04:45
10-22-2016 04:45
I bought myself a blaze in March 2016, After months of working good, its now dying on me. For the past week its battery started to drain faster, i would charge it in the morning and by afternoon it would be blank. NOw since today morning when i put it on charge its charging from red icon to green icon, and as i remove it from the charger its going blank again. When i put it back to charge, it will show red and charging again!! Its not charging and i cant wear it anymore as its going blank!!
Anyone experiencing this issue, kindly share!
10-29-2016 02:28
10-29-2016 02:28
Problem solved! The support team sent me a new blaze!!
Thank you support team.
Best Answer10-22-2016 05:37
10-22-2016 05:37
Have you tried a restart yet? Press left and lower right button for a few seconds until the Fitbit symbol appears.
10-22-2016 11:48
10-22-2016 11:48
10-22-2016 14:39
10-22-2016 14:39
i am not able to do that as when i take it off charging it goes blank and does not respond to any button presses including what you have suggested to me.!!
@The_Lion wrote:Have you tried a restart yet? Press left and lower right button for a few seconds until the Fitbit symbol appears.
Best Answer10-22-2016 14:57
10-22-2016 14:57
Open the cover of the charger. Push the tracker down so that it keeps charging. Then restart it.
Best Answer10-29-2016 02:28
10-29-2016 02:28
Best Answer10-27-2018 16:45
10-27-2018 16:45
My Fitbit blaze for a year will not hold a charge for one day. i purchased a second charger earlier now it will sit on the charger for a day with no change. This is my second Fitbit.
Best Answer11-27-2018 21:13
11-27-2018 21:13
Restarting didn’t work for me nor did holding the tracker down firmly in the recharging unit
Best Answer11-27-2018 21:17
11-27-2018 21:17
Now several I know my son and I and others can not charge the blaze. Seems no answer and two years life give no response from Fitbit. Seems I can not trust. Suggestion of a new smart reliable watch.
11-27-2018 22:16
11-27-2018 22:16
Best Answer11-27-2018 22:23
11-27-2018 22:23
Best Answer10-06-2020 07:04
10-06-2020 07:04
THANK YOU !!!!!!!!!!!!!!!!!!!!!!!! That worked
