04-03-2017 20:49 - edited 04-03-2017 21:34
I got my new FitBit Blaze today and after having it on charge for the past 2hrs there has been no progress in the charging and the battery icon on the app has remained red.
I have been told that I won't see the progress of the battery charging until I have updated the Blaze, but can't do this until the battery is charged.
When trying to update the Blaze it continually says "Your Blaze's battery is too low to continue". Plug it in and charge it up before trying again. Like I mentioned it has been on charge (yes the prongs are aligned and the case clicked when I closed it, tried several different USB ports and plugs) for 2hrs or so with no progress.
Has anyone had this problem and it resolved and eventually fully charged itself or am I handling a faulty Blaze?
04-03-2017 21:01
04-03-2017 21:01
My new blaze is not charging either but it doesn't even show battery icon. Just logo and web URL...
@nic13b wrote:I got my new FitBit Blaze today and after having it on charge for the past 2hrs there has been no progress in the charging and the battery icon on the app has remained red.
I have been told that I won't see the progress of the battery charging until I have updating the Blaze, but can't do this until the battery is charged.
When trying to update the Blaze it continually says "Your Blaze's battery is too low to continue". Plug it in and charge it up before trying again. Like I mentioned it has been on charge (yes the prongs are aligned and the case clicked when I closed it) for 2hrs or so with no progress.
04-03-2017 21:24
04-03-2017 21:24
That is the same screen mine is showing.
04-04-2017 00:35
04-04-2017 00:35
I am having the same problem with my new Blaze. I have sent an email to Fitbit support. It will be interesting to see their response
04-04-2017 03:08 - edited 04-04-2017 03:09
Interesting update - I had been setting up my new Blaze while I was at work using my computers USB port and my FitBit app over a 4G network.
I got home and plugged the Blaze into my iPhone charger and the FitBit app had connected to my
home WiFi. The Blaze had started updating within 5mins and was fully charged within 30mins.
Coincidence?
