02-29-2016 14:39
02-29-2016 14:39
02-01-2017 14:38
02-01-2017 14:38
I had to open another account. I then put the device back in the frame. It began to download the file. Perhaps it needs to be in its frame in order to work. Take it out to charge and put it back to do anything with it.
02-01-2017 16:40
02-01-2017 16:40
Check the help guide at http://help.fitbit.com/articles/en_US/Help_article/1190/
Ive also noticed of my battery has been dead for a while, it might take an hour or two before the tracker shows any sign of life.
02-02-2017 08:23 - edited 02-02-2017 08:23
I just got my Blaze for my birthday and I am having the same problem everyone else is. It will not finish setting up because it is not charged, so I plugged it into my computer and my computer makes certain sounds when the USB port is being used, which it made that sound which I'm guessing it means that it is charging? I'm not sure because the screen is the same Fitbit.com/setup. Will the battery show at all or do I just leave in for a few hours?
02-02-2017 08:30
02-02-2017 08:30
02-05-2017 18:49
02-05-2017 18:49
Checked all, still not charging.
02-05-2017 18:54
02-05-2017 18:54
Tried. Update still reports battery too low. Thanks for trying.
02-05-2017 20:30
02-05-2017 20:30
I am having this problem as well. What did you do to fix it? I cannot set it up and upgrade it to the latest software because the battery is too low, yet it wont charge
02-05-2017 20:41
02-05-2017 20:41
02-05-2017 22:30
02-05-2017 22:30
IF the battery is being teported as low, then place the Blaze into its charger and plug it into a powered up usp socket. Use the computer or a phone charger. If the Blaze vibrates when first pligging in, you know that it is charging.
As has been said many times, if the www.fitbit.com/setup is on the screen, there will not be any battery indicator showing. The vibration is all you will get.
02-10-2017 14:00
02-10-2017 14:00
After the upgrades the battery will show.
02-12-2017 10:04
02-12-2017 10:04
I am having the same problem. Did you manage to get yours corrected?
02-12-2017 10:38
02-12-2017 10:38
02-16-2017 21:03
02-16-2017 21:03
will it still charge if its not set up? Because my phone wont let me set it up becase it needs to be charged.
02-17-2017 01:56
02-17-2017 01:56
02-17-2017 19:57
02-17-2017 19:57
I'm trying to charge my blaze. I get the fitbit. com/ setup screen with the aqua dots; but, no charging symbol and then it goes black after a few seconds. What am I doing wrong? I have tried both of my chargers.
02-27-2017 10:08
02-27-2017 10:08
**ahem**ing bull**ahem** crap...i received mine today and its 2hours and nothing happens... still shows battery in the red
02-27-2017 10:21
02-27-2017 10:21
@lunar5577 nay we have a little mire history. What do you have the trackwr plugged into? A phone charger or computer?
When first plugging in do you feel a slight vibration?
03-01-2017 04:23
03-01-2017 04:23
I have the exactaly same problem with my Blaze! Did you resolve?
03-01-2017 04:32
03-01-2017 04:32
I'm going through the exact problem with my Blaze. I brought my Fitbit Blaze in november 2015 at Bestbuy whe i was in Orlando. I've been trying to load my device for two days withou sucess.
To clarify:
Tried hard restart (hold left button and lower right button for 10 seconds)
Tried two charging cradles
Tried multiple USB wall outlets, laptop USB ports, USB plug adapters
Pins aligned in charging cradle
Device pressed in and clicked
Can you help me?
03-02-2017 05:09
03-02-2017 05:09
I have problem with charge too. What I do:
1. install apps in windows 10 laptop
2. put Blaze to charge with USB - can not sync because baterry low
3. wait cca 1h - on Blaze monitor was just setup notification
4. after cca 1h open app on laptop, go to dashboard and see that battery half charge
5. from dashoboard/settings go to start update (not from my mobile phone or bluetooth)
6. finished and now see clock and battery charge indicator
sry for my english, not native language 🙂
