02-29-2016 14:39
02-29-2016 14:39
07-14-2016 07:37
07-14-2016 07:37
Thanks Angela and @ColoradoSun! I'll contact them this morning and suggest that.
07-14-2016 21:37
07-14-2016 21:37
07-16-2016 05:52
07-16-2016 05:52
Hello @Fitnessfan1! keep me posted 😉 @ColoradoSun thanks for sharing! ![]()
I'll be around if you have any questions!
It is health that is real wealth and not pieces of silver and gold! Share your story!
07-17-2016
06:44
04:39
AngelaMa
07-17-2016
06:44
04:39
AngelaMa
Hi Angela, I spoke to Customer Service and they are sending me a new
tracker. Since my band is fine and the charger seems to be working, they
are replacing that one part. Let's hope it works! Thanks for the help.
Moderator edit: removed personal information.
Best Answer07-17-2016 06:51
07-17-2016 06:51
Best Answer07-17-2016 10:45
07-17-2016 10:45
Best Answer07-18-2016 04:42
07-18-2016 04:42
Welcome to the Fitbit Community @Tammygirl! if you are experiencing issues with your tracker, get in touch with our support team, you can reach them via chat, email or phone and they will be happy to take a look at your tracker's back-end information and provide you personalized troubleshoot. @ColoradoSun thanks for sharing this information. @Fitnessfan1 That's great to hear! Keep me posted.
I'll be around if you have any questions! ![]()
07-18-2016 05:03
07-18-2016 05:03
07-21-2016 06:24
07-21-2016 06:24
Hello @Tammygirl thanks for the update! I'm glad to know that you are back on track. 🙂
Hope to see you around more often! ![]()
07-24-2016 12:06
07-24-2016 12:06
Okay....so I seem to be having the same issues as the rest of the known universe with charging. I see the battery icon on the screen when placing it in the cradle for about 1 second, it disappears and is replaced with the fitbit logo and fitbit.com/setup. I do not see a battery icon in the upper left corner. Am I charging or not?
07-24-2016 14:21
07-24-2016 14:21
Best Answer07-24-2016 15:50
07-24-2016 15:50
07-24-2016 16:02
07-24-2016 16:02
@RobertF1967 has your Blaze been setup yet? Your problem sounds completely unrelated to what the thread is about.
If your Blaze has never been setup to your account, then yes it will display the setup message.. Now if it has been setup, showing your step count, but when placing it into its charger gives. Hee setup message, than there are bigger problems than we can help you with here and you will need, I contact fitbit... Http://contact.fitbit.com
07-24-2016 16:38
07-24-2016 16:38
Best Answer07-24-2016 16:48
07-24-2016 16:48
Best Answer07-24-2016 17:11
07-24-2016 17:11
Place it in the charger, leave it in, use the phones charger, and try again.. It continues from where it left off, and doesn't have to start over.. It will work.
07-24-2016 22:24
07-24-2016 22:24
I was having the problem of my Blaze not charging, and the customer service rep I talked to, asked me to sync the device and that fixed the problem.
Best Answer07-25-2016 20:46
07-25-2016 20:46
Thank you so much for your post. I tried Fitbit, web and cound not get an answer to why I had a red bar within my Fitbit's charging icon. When I changed the charging station for my Fitbit, it began to charge as it should with NO problems. Fitbit's instruction to turn off and then on was terrible advice! Need to get their personnel more familiar with what I believe could be a common issue.
Best Answer07-26-2016 06:42
07-26-2016 06:42
Best Answer07-26-2016 10:54
07-26-2016 10:54
Welcome to the Forums @Vincejsmith, @RobertF1967 and @3Skipper3! It's great to have you here. As @Rich_Laue mentioned if the Blaze is not set up to the account it will not display the battery icon. Also if your battery is not charging the advise from @Vincejsmith to clean the contacts is a great idea. You can also try changing USB port or use another USB certified wall charger. If your battery is not charging after this please contact our support team for assistance. @RobertF1967, @curt81 and @Fitnessfan1 it's great to see you around!
Tag me if you have any questions! 🙂
