02-29-2016 14:39
02-29-2016 14:39
12-21-2016 10:01
12-21-2016 10:01
12-21-2016 10:57
12-21-2016 10:57
12-24-2016 18:06
12-24-2016 18:06
GOty blaze today and it will not update or setup as it says no battery. But when i plug in nothinv happens. Plugged it into comp and also usb charger but nothing. Cant setup without battery but not sure it will.charge either. Been plugged in for at least half hour
12-25-2016 01:48
12-25-2016 01:48
I had the same issue - during inital set-up, Fitbit said battery was too low and couldn't finish set-up. However is you plug the Fitbit into the crable via aPOC and charge. YOu can carry on with the setup (which requires a software update too) the Fibit springs to life.
I hope this helps everyone in the same position.
Happy Holidays
12-25-2016 05:51
12-25-2016 05:51
I got my blaze today. didnt charge or update.here is what i figured out on how to get it going. hope I can save you some wasted time.
1.be sure to place blaze in charger with pins aligned, charge with Wall charger NOT PC. (windows doesnt recognize it and shuts down the USB port.)
2.you can pair it before or after to app, but let it charge for half hour or so. there will NOT be any indication of charging but it does.
3. on your app once paired check the battery level, when its half charged or so, update the firmware keep the fitbit charging.
12-25-2016 10:38
12-25-2016 10:38
I was is the middle of setting up my fitbit blaze when it just shut off. I plugged it into a usb and there was no indication of it charging. I think it may be defective.
12-25-2016 10:55
12-25-2016 10:55
@PierceRodyour battery probably just died.... plug it in to a wall outlet usb charger, not your computer.
12-25-2016 11:47
12-25-2016 11:47
This worked perfectly. Plugged it into a wall using my phone charger and it was halfway charged in about 30 minutes. I was then able to do the entire update.
Thanks a bunch.
12-25-2016 23:34
12-25-2016 23:34
I have had the same issue...with 2 different Blazes as I took the first one back.
12-25-2016 23:57
12-25-2016 23:57
Same problem as guydebyl. Says battery too low but tried both computers and several usb ports and nothing
12-27-2016 23:13
12-27-2016 23:13
Jim that is me to a tee
12-28-2016 06:56
12-28-2016 06:56
Did you read the messages directly above and try the suggestions? You can't charge it out of the box (usually) using a computer or USB hub. It will not charge. Use a charger you can plug straight into the wall. Wait 30 minutes and try the update.
12-29-2016 10:42 - edited 12-29-2016 10:44
Solved:
Like a lot of you, I had purchased a Fitbit Blaze and it was not charging. I actually had a replacement sent - the replacement also would not charge. Two different units, two different docks - nothing. Spoke with support, they asked for me to perform basic and common sense type of troubleshooting that I had already tried :
Plug into USB port on computer - tried two different computers - no charge
Try plugging into a wall jack via a usb adapter - tried two USB adapters - no charge.
Finally - tried a generic usb wall adapter. I was previously using a usb adapter for my cell phone - Samsung Galaxy. I tried two adapters , both were Samsung phone usb wall adapters. I then used a generic usb wall adapter I found laying around the house that I had used in the past for an older phone - charged right away and I was able to update the Fitbit and it is now working correctly.
Fitbit support, I suggest looking into this issue as I'm sure many people will try charging with a phone usb charger and it might not work depending on the usb adapter they are using - also, why is the Fitbit Blaze not sent with an adapter?
12-30-2016 23:00
12-30-2016 23:00
I'm with you on this! How can so many people be having the same problem. Clearly this is a design fault. I am having the same problem and finding it difficult to get through to customer support. I sync'd my new blaze to my account as I had the four numbers displayed on the blaze but that was the end of the process as my computor indicates there is no charge on the blaze. I have followed all of the instructions correctly for charging but get nothing but the fitbit.com/set up screen on the blaze. I have tried the 'shut down and restart' instructions but nothing happens. It doesn't shut down at all and I still have the same fitbit.com/set up screen.
12-31-2016
01:06
09:40
SantiR
12-31-2016
01:06
09:40
SantiR
Hi all,
I went to get a refund from JBHi Fi today, but a young lady there was able
to download some firmware and get it to charge. So now I'll have another go
at getting it going!
Moderator Edit: Removed Personal Information
12-31-2016 06:14
12-31-2016 06:14
12-31-2016 13:33
12-31-2016 13:33
today 12/31/16 i purchased brand new blaze. I was replacing my charge hr with the Blaze. I cannot get it to charge in the cradle. what I do see is the fitbit logo and that is all. No battery showing progress, nothing....... I am not able to tell if it is on and I am not able to pair it. I am not able to add device to my fitbit account. I am beginning to wonder why I did this? Please assist. thank you.
12-31-2016 14:43
12-31-2016 14:43
For
How are you trying to charge it? For me I couldn't charge it via my computer usb or my Samsung Galaxy usb wall adapter. I also tried multiple docks and even had a replacement Blaze sent, had the same issues. I ended up using an old usb wall adapter that was just a generic one I got a couple yrs back, it charged right away. After it was charged I was able to sync it and update it. Working great now.
12-31-2016 17:43
12-31-2016 17:43
12-31-2016 17:59
12-31-2016 17:59
@REi77Y I'm glad you are up and stepping.
For you and @catinmylap while the Blaze has the www.fitbit.com/setup the software is not running the main program and will not display any charge indicator, it will gently vibrate when it is connected to the charger.
So yes until the tracker is setup and firmware updated, there will be nothing on the display showing that it is charging.
Then again it might not need to be charged. The app will tell you sitting the setup process.
