Hi, @TeraB.! You can restart your Blaze by holding the left and bottom right buttons down for about 10 seconds. I would also try cleaning the charging contacts on the back of your tracker and if you haven't already done it, try plugging your charging port into a different source (e.g., if it was plugged into a computer, plug it into the wall).
MakMak | Community Council
