01-24-2018
09:59
04:23
AlejandraFitbit
01-24-2018
09:59
04:23
AlejandraFitbit
Device confirmed as faulty.
Best Answer01-24-2018 11:06
01-24-2018 11:06
See this thread where someone got it set up successfully
https://community.fitbit.com/t5/Blaze/Blaze-being-able-work-with-my-S8/m-p/1951182/thread-id/55585/h...
Wendy | CA | Moto G6 Android
01-24-2018 14:28
01-24-2018 14:28
Are you referring to the Galaxy S8 which are now on the supported list, and works for my 3 siblings and me.
They have no problems, I have occasional syncing problems.
01-24-2018 19:23 - edited 01-26-2018 13:26
Fitbit confirmed its faulty
Best Answer01-25-2018 04:09
01-25-2018 04:09
Welcome to the Forums @Sassy_38, thanks for troubleshooting this by yourself and @WendyB, @Rich_Laue for stopping by.
There are some users that aren't having issues connecting their trackers to their Samsung S8 but there are some that are experiencing some issues. I would like to know if you have tried to restart your Fitbit? If you haven't, I recommend restarting it. After this process, make sure you are doing the following from your Fitbit app to set it up:
If you keep having issues, keep in mind that you can always use another device to paired your Blaze and then from your phone, just log in to your account.
I hope this helps, let me know the outcome. ![]()
Best Answer01-25-2018 04:35 - edited 01-26-2018 13:25
Device was confirmed as faulty
Best Answer01-25-2018 08:45 - edited 01-26-2018 13:24
Device is confirmed as faulty
Best Answer01-25-2018 10:26
01-25-2018 10:26
I, too, am having trouble. I just updated my Samsung S6 to S8. My Blaze will not synch. I have tried all the recommeendations suggested on the website and nothing seems to be working. I have been using my Ftbit successfully for two years now so am not a novice. Help! Will I have to purchase a new Fitbit to be compatible with my new phoe?
Best Answer01-25-2018 16:12 - edited 01-26-2018 13:25
Device has been confirmed as faulty
Best Answer01-26-2018 11:55
01-26-2018 11:55
I'm new to fitbit, just bought a Blaze yesterday. I went to fitbit.com/setup, created an account, downloaded the app from google onto my S8 and opened it. It asked for the four digit code being displayed on the blaze, (which I hadn't even noticed until then), and once I entered the code it started syncing with my S8.
Hope this helps.
Best Answer01-26-2018 13:29
01-26-2018 13:29
Fitbit confirmed its a fault.
Best Answer01-26-2018 13:49
01-26-2018 13:49
Yes @Sassy_38 Fitbit has confirmed that it is faulty, did they offer some type of resolution?
01-28-2018 04:25
01-28-2018 04:25
Hello all, I hope you are doing fine.
I want to thank you all for the information provided here. If you have a Samsung Galaxy S8/S8+, I recommend taking a look at this post, where you will be able to find more information about the issues you are having.
I hope this helps, catch you later. ![]()
