08-25-2016 01:15
08-25-2016 01:15
10-02-2018 04:19
10-02-2018 04:19
I have had the same problem with my blaze and Iphone 7. And I just fixed it! I went into the settings on the watch and bluetooth was off. So I tapped it and it changed to pair. Then I went into the phone's bluetooth settings and paired it. Next I opened the fitbit app and it asked me to pair with the blaze, again. So I did.
Now, when I open a gps exercise, I then open the app and the blaze connects to the phone's gps.
Best Answer02-27-2020 15:27 - edited 02-27-2020 15:28
I had the same issue. What I did to fix the issue was to switch to classic Bluetooth connection and he app open. oh and FYI android 5.1 and oneplus 6
Best Answer06-07-2020 08:21
06-07-2020 08:21
I have the same problem. Done all that has been suggested and more. Deleted and reinstalled app, repaired device etc. but nothing works. I’m really disillusioned with Fitbit. Having to use Strava which is not acceptable.
Best Answer06-07-2020 11:56
06-07-2020 11:56
iOS I cant help much with.
Android I can.
@ats1075 you have one of, or both of two problems.
Make sure that the app is running in the background before the phones screen times out.
Also through the phones settings disable power management with the Fitbit app.
I also find that restarting the phone, gets the gps connected long before the phone is usable.
@NewSpringer without knowing the phone you are asking about, not sure if I was helpful.
What should I know about using the Fitbit app on my Android phone?
