Blaze not connecting to phone after update
ANSWERED
My blaze won't connect to my iPhone 6s+ since the update. The Bluetooth thing says it's connected but it won't sync or get notifications. I tried deleting the blaze from the app and setting it up again but now it's stuck on the screen that says "we found your tracker" and "connecting to tracker" and will sit there for hours. I tried deleting the app and reinstalling but that did nothing. I tried resetting the Fitbit but that also did nothing. Please help.
1 BEST ANSWER
Accepted Solutions
After about 2 weeks it just started working again. Idk why, I didn't do anything different, just kept trying the same thing over and over again.
29 REPLIES 29
There have been reports of this with the IPhone, killing the app and restarting, people find that the Blaze is set back up.
I have tried that multiple times. Didn't help
Welcome to the Fitbit Community @Bigbake! It's great to have you here. 🙂 Are you still experiencing syncing issues with your Blaze? If you are have you tried syncing with a computer? @Rich_Laue thanks for your cooperation.
Keep me posted.Smiley Wink
Retired ModeratorAngela | Community Moderator
It is health that is real wealth and not pieces of silver and gold! Share your story!
Same issue.  After update Blaze only sporadically connects w/Iphone.  The tempprary fix is to hard reset the Blaze (button hold) TWICE.  Does not work until the second reset.  Just tried removing device and setting up again.  We'll see if that helps.
Hey @wxman123 hope you are having a very active day! 🙂 Thanks for sharing the troubleshoot, let me know how it goes after setting your tracker as a new device.
Happy stepping Smiley Very Happy
Hello @Bigbake It's great to know your Blaze is syncing properly now! Thanks for sharing 🙂
Hope to see you around more often! Smiley Very Happy
Angela, I know this isn't the correct page but I found you here- nothing I do from the manual helps me to pair my new Blaze to my iPhone 6. Thoughts?
Hello @Robertshaw6 welcome to the Fitbit Community! are you still experiencing issues with the set up process? If you are you can find the troubleshooting steps on this link
Keep me posted! 🙂
After updating the latest app, iPhone 6, the blaze is connected by Bluetooth and will control music, however, no activity will connect. I reloaded twice and rebooted the blaze, help!
@Nucbee welcome, welcome! I'll be happy to help here. Smiley Happy So you mean to say that your Blaze isn't syncing to your iOS device? Please note that the latest iOS release is affecting syncing on select Blaze trackers. On your mobile device go to Settings > About. If the Version is 10.1.1 or below, you're not affected by this issue and it's likely your syncing difficulty is caused by a missing requirement or other common issue. Do clarify that info for me. If the version is 10.2 or 10.2.1, update your Blaze to the latest firmware version (8.301.8) to resolve the issue. Hope this helps, keep me posted!
Mariam | Community Moderator, Fitbit
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
Ive done all of the troubleshooting and my blaze is still not syncng with m phone.  Now my phone cannot even find it when it is lying right next to it
@dg1253 a couple questions I do have.
Has your Blaze been setup? If not it will need to be.
If so have you checked http://www.fitbit.com for your steps?
If they don't show up there steps to try, with a sync inbetween.
- turn off/on the phones Bluetooth
- remove the tracker from the phones Bluetooth settings, not the app
- restart the phone
-restart the Tracker
What type of phone do you have?
How do I update the blaze to the newer version? I do have the 10.2.1 version on my iPhone . Please help!
@Rosed69 welcome to the forums! To update the firmware version of your Blaze please follow these steps. The latest version of your Blaze's firmware is 8.301.8. Hope this helps!
I experienced the same problem. I resolved it by closing all the apps on my iPhone and turning it off then turning it on again. The Blaze connected with no problem and quickly synched all my activities.
A warm welcome to our new friend @PElhindi! Thanks for sharing what worked for you! This is definitely going to be helpful to other users! Keep it up and hope to see you around more often. Smiley Happy Heart
After all, that's what community is all about; sharing knowledge and experiences so we can find solutions. Way to go!
Hi,
I don't know if it's related to the update but my fitbit blaze only connects to my Iphone6 if I reboot the watch. It literally doesn't connect any other way. I have to reboot the watch to receive any data. It's like the watch disconnects the Bluetooth. Can someone help?
Kind regards,
@Sakhmet welcome aboard! This definitely doesn't sound like normal behavior. In this case, I recommend troubleshooting your Bluetooth using the steps @Rich_Laue posted here. I really hope this helps, keep me posted! Smiley Wink
