03-10-2016 23:41
03-10-2016 23:41
03-17-2016 05:14
03-17-2016 05:14
Best Answer04-06-2016 23:40
04-06-2016 23:40
Best Answer04-07-2016 09:12
04-07-2016 09:12
I connect to bluetooth pairing with problem but it constantly turns off.
I have not seen any text messages since yesterday.
I turned bluetooth on and off, all notifications are on, i turned the phone on and off, i restarted the Blaze
the message app is correct.
When i first set up the blaze it worked fine, now nothing no matter what combination i try.
My Galaxy S-6 did an up grade yesterday, the fitbit app is not yet upgraded.
i should not be wasting so much time on something that should help make my life easier. This is really unacceptable. I loved the Blaze when i first received it, but now it just becoming an annoying nuisance, with all the sub-par issues.
04-07-2016 18:40
04-07-2016 18:40
Bluetooth Classic is not used for notifications, and can be left out of your not using the music control.
On the S6 do you get a pop up message with an incoming text? This would be a small box with the message on it.
Best Answer04-09-2016 07:30
04-09-2016 07:30
it is working perfectly now...i removed the app from both my phone (Galaxy s-6) and Tablet (Galaxy- S2) and then reinstalled...(the phone itself had updated and i think it may have skewed something. doing this also gave me my new friends listing from a new group that did not show up on the apps, only on the dashboard.
thanks to someone on another thread i scanned bluetooth a couple of times, got the "yes" and was able to switch bluetooth to ON instead of just paired which constantly turned off.
i got some other specific instructions from Customer Service which worked with what i did above and miraculously, everything is behaving as it should--i get a slight vibration when i get incoming calls, and can read the full text messages on the Blaze(pop-up does show)...HURRAY!! i hope that everything stays this way.
i DO need the bluetooth classic according to Customer Service. i don't care as long as everything works. thanks for reading.
Best Answer04-14-2016 12:38
04-14-2016 12:38
Silvia, that link is no longer working. I'm also trying to set up my new Blaze and can't connect to either my desktop (Mac) or iPad using Bluetooth.
Help?!
Best Answer04-14-2016 14:29
04-14-2016 14:29
@Bazynga A warm welcome to the Community! I already updated my post and now the link is working
. I've noticed that some users have had issues when they are setting up the tracker using the mobile phone because it gets stuck, if you're having this kind of issue then please reboot your phone and tracker. After this, try the set up procedure once again.
Also, you can check this post to know how to set up your tracker using a mobile device.
Hope this helps. Let me know how it goes.
Best Answer04-14-2016 16:02 - edited 04-14-2016 16:25
Silvia, it's working - thanks! I rebooted my phone and that seems to have done the trick. Am happily exploring my new new toy!
10-29-2016 06:04
10-29-2016 06:04
10-29-2016 06:18
10-29-2016 06:18
@Andy_evans44 first thing is your Blaze still connected to your Fitbit account?
Now if you are trying to pair through the phones BT screen your seeing the expected,
This needs to be done through the fitbit app.
Does the Blaze show as a connected device in the app?
Best Answer10-29-2016 07:35
10-29-2016 07:35
Best Answer10-30-2016 20:15
10-30-2016 20:15
Just bought my Blaze, very fired up and can't get it to sync with my Samsung 5. Done everything suggested - rebooted, bluetooth on/off, scan....nothing. Laptop shows the device, only thing on the phone is the initial set up image.
App on the phone just shows the Blaze syncing with the wheel of fortune going round and round
Help!
Best Answer10-30-2016 23:51
10-30-2016 23:51
Best Answer06-09-2017 17:56
06-09-2017 17:56
I cannot get my Blaze two pair to my S4 Samsung phone at all period I have tried everything listed here on the forums. I'm going to take the thing back to the store tomorrow I've spent well over three hours trying to get this thing to work. Like I said I've done everything I've turned off the Wi-Fi I've uninstalled the app reinstall the app restarted the phone you name it I've done it. I do see the blaze showing up in my Bluetooth devices on my phone but of course it's not paired and you cannot pair it that way. I wonder if there are compatibility issues with the Blaze and the S4 even though it shows it as a compatible product when I go to Fitbit website. For this kind of money Fitbit needs to figure something else out nothing should take this long for customers!
Best Answer06-09-2017 21:33
06-09-2017 21:33
@Soulcommander, why not follow the instructions posted more than a few times above, or in the docs at http://help.fitbit.com/?q=setup
Or your manual in the help site at http://help.fitbit.com/?p=blaze
Please open the app, log into your account and do an add tracker routine.
Once the tracker is connected to your account, the app will pair it to the phone if it needs to.
This pairing to the phone can not be done by the user, and will get a rejected message Everytime.
Best Answer06-09-2017 22:09
06-09-2017 22:09
I did all that I read every thread here in this post including the manual from Fitbit. I noticed there are some issues with Samsung S4 phones as well where not everything is supported. After over 3 hours of fiddling around with it I decided wasn't worth it took the Blaze back to the store. If they are going to develop these watches then they need to work on the firmware so they are more compatible with all devices.
Best Answer06-10-2017 05:35
06-10-2017 05:35
@Soulcommander the problem is more in the app, especially with Android that could require a separate build for each model? Thus is because there is no standards with Android phones.
Best Answer06-10-2017 06:36
06-10-2017 06:36
It's definitely an application problem and firmware issue. My phone is able to see the Watch it's just the communication between the application and the phone. And then if you can connect which in my case you can't there are other issues the phone is not able to perform all the functions with the watch so I have read.
Best Answer07-19-2017 19:18
07-19-2017 19:18
I've had my Fitbit blaze for less than a year and I've had trouble trying to sync the connection via wifi to the Fitbit app. I've tried to find it via Bluetooth on my iPhone 6 but it won't even give me an option anymore? Is it possible to wear out the sensor? I feel like that shouldn't happen but I'm definitely no expert!
Best Answer07-21-2017 06:45
07-21-2017 06:45
Welcome to the Community @Robertflehner! If your Blaze isn't syncing to your account, please try the following troubleshoot. Your tracker won't connect directly from the phone's Bluetooth, it will sync using your Fitbit app.
I would like you to double check that your Blaze is still paired to your Dashboard by going to the main page and you should be able to see the tracker's picture.
In regards to your question, the sensor shouldn't wear out.
Keep me posted!
