I myself find it really iffy. I try 3 times and give up.
You do need to make sure you are in good light so it picks up GPS. But even then it works sometimes not all
Wendy | CA | Moto G6 Android
Best AnswerCheck the steps in this post
Is your phone compatible
Generally if the fitbit app is in memory a restart of my Android device gets the GPS connected.
Best AnswerThanks for the links,
i have a Samsung A8 which doesn't appear in the phone compatible list. The app works fine, and there are no issues with the synchronization between the app and blaze.
The GPS connection is very erratic. Some time it does get connected and then breaks off.
