03-26-2016 21:51 - edited 03-27-2016 08:06
I already searched this forum and found no answer to it except explaining how it works..
here is what i did and found this as a problem.. I live in a high rise building (7th floor) and took stairs to go down and up multiple times with in last 3 days and my floor count is not working... in one case it counted "1 floor" only ... today it counted "7" only... there are around 126 acutal stairs which is not accounted for. What I am doing wrong? or my device is broken? or its a software issue?
P.S: I just got a new Fitbit blaze last thursday and since the mail delivery i am using it after updating my device.
03-26-2016 22:51
03-26-2016 22:51
@ssultanali wrote:I already searched this forum and found no answer to it except explaining how it works..
here is what i did and found this as a problem.. Currently I leave in a high rise building (7th floor) and i took stairs to go down and up multiple times with in last 3 days and my floor count is not working... in one case it counted "1 floor" only ... right now it counted "7" only... there are around 126 acutall stairs which is not accounted for. What I am doing wrong? or my device is broken? or its a software issue?
@ssultanali Welcome.... You could be experiencing a neutral pressure in the building because if the Fitbit doesn't detect and change in air pressure every 10' it will not register a stair/floor.
The reverse can happen if you are out in a windy environment you could get changes in air pressure around your Fitbit and it will register phantom floors..
Now that you detected 7 floors upwards that would appear to be correct for a 7 storey building..
The benefit you get from the stairs is the effort.. Fitbit does nothing with the stairs, it is an incentive measure to get us moving in a different environment.
Enjoy your Blaze because mine has been excellent over the last 4 weeks..
03-26-2016 22:51
03-26-2016 22:51
03-26-2016 23:46
03-26-2016 23:46
Did you do a restart of the Blaze yet?
Blaze only counts stairs going up, and approaching storms while walking, OK any decrease in air pressure can do it.
03-27-2016 08:00 - edited 03-27-2016 08:01
The stairs are not open its kind of indoors so its not windy... here is the picture of stair in question.
I did restart still no avail
03-27-2016 08:03
03-27-2016 08:03
the 7 floor it counted was acutally last stair that are outside my building...
03-27-2016 09:21
03-27-2016 09:21
Mike | London, UK
Blaze, Surge, Charge 2, Charge, Flex 2 - iPad Air 2, Nokia Lumia 925 (Deceased), iPhone 6
03-27-2016 10:36
03-27-2016 10:36
first time it counted as 11 (went up and down 7 floors)
second time counted as 2 (went up and down 7 floors plus some addition flights of floor at other place)
third time counted as 9 (went up and down 7 floors)
forth time counted as 7 (went up and down 7 floors)
03-27-2016 10:42
03-27-2016 10:42
04-18-2016 11:55
04-18-2016 11:55
I just received my Fitbit Blaze a few days ago. It seemed to be working great but then today, it quit counting my floors. I know it detects altitude changes when I'm walking and I walked the same path today as I did yesterday and the day before. I was showing 15 to 20 floors which was about right for the rise in elevation, but today when I walked the same path, it showed 0 floors.
I have restarted my Blaze 3 or 4 times and that did not help.
05-10-2016 11:33
05-10-2016 11:33
My blaze is inconsistent in counting my floors - today it will not register my stairs/floor in my home - consistently not counting - owever works fine outside on hills. I am in a contest at work so this really sucks - for the price of the device it should work more consistently--- it has also been inconsistent in counting steps---
05-10-2016 12:49
05-10-2016 12:49
Mine will occasionally give me more floors than I actually went up.
05-25-2016 07:48
05-25-2016 07:48
07-30-2016 03:51
07-30-2016 03:51
07-30-2016 04:01
07-30-2016 04:01
08-11-2016 20:52
08-11-2016 20:52
The ability to edit the amount of floors would helpful for tracking purposes.
08-31-2016 11:54
08-31-2016 11:54
09-01-2016 04:57
09-01-2016 04:57
Hello all, I hope you are doing fine! If you are having problems with your floors accuracy, I recommend restarting your Blaze. After the restart process, do the following:
1. Find a location where you have 2 flights of stairs in a row. Each flight of stairs should be at least 10 feet tall.
2. Place your tracker on your belt/waistband and check the number of floors before you begin to walk.
3. Walk up the 2 flights in a row, trying not to stop at any point.
4. Once you reach the top of both flights of stairs, stop to look at the number counted.
If you see that the amount of floors stills inaccurate, feel free to contact our support team, for a faster response you can contact them via phone or chat.
Let me know the outcome.
09-01-2016 10:23
09-01-2016 10:23
It appears the Blaze is not calculating the floors correctly when there is low pressure weather system in the area (rain).
09-02-2016 07:27
09-02-2016 07:27
Now the the low pressure system passed the area, the Blaze is counting the floor properly again.
Yes, it is weather related. Fitbit needs to look into this. May be add a barometric sensor to help with the calculation.
03-06-2017 18:07
03-06-2017 18:07
We had near tornado weather today. I apparently walked 36 floors today.... when really maybe 2. So cool it goes by barometric pressure!
