02-27-2016 14:51
02-27-2016 14:51
I got my Blaze a couple days ago and have been wearing it along with my One. It seems every day it counts less flights of stairs. Today, after it counted 9 flights, I walked up the stairs at home 7 times and Blaze didn't add to the count. I'm stuck on 9 flights for today. The One says 21 flights of stairs. I did reset the Blaze and that still didn't work. Could mine be defective?
04-29-2016 14:52
04-29-2016 14:52
I just tested it. It counted the steps but it still only says I've gone up once today. I've gone up at least 4 or 5 times...
Best Answer04-30-2016 00:34
04-30-2016 00:34
04-30-2016 03:28
04-30-2016 03:28
Best Answer05-02-2016 03:33
05-02-2016 03:33
If there are days when it is accurate and there are days when it is not accurate, I guess that has to do something with atmospheric pressure changes?
Best Answer05-02-2016 18:24
05-02-2016 18:24
I don't think it has ever been accurate but I've been holding my arm up as I walk and that seems to do the trick. Although I also realized that I usually run up 2 stairs at a time so maybe that is confusing it? I don't know.
Best Answer05-16-2016 09:46 - last edited on 05-16-2016 11:26 by SunsetRunner
They should give us an option to manually input stairs climbed.
Moderator edit: format.
05-16-2016 11:15 - edited 05-16-2016 12:16
@sknight I know you are frustrated, please remember your comments here are directed to fellow Fitbit users.
My thoughts on Stairs counted are.
06-02-2016 13:58
06-02-2016 13:58
My Fitbit Blaze hasn't been counting stairs either. This sounds silly. But, I got it to recognize stairs by doing this...Before I climb a fight of stairs, I put my fitbit hand down near the ground. And, slowly raise it as I climb the stairs. So, when I land at the top of the flight of stairs, my fitbit arm is stretched as far as it can go over my head. And, then my fitbit registers the stairs. It's not ideal. Especially for how expensive the Blaze was. But, at least its logging the stairs now.
06-02-2016 20:17
06-02-2016 20:17
Best Answer07-05-2016 17:12
07-05-2016 17:12
Alta NOT counting stairs. Have 18" ceilings in my house with 17 stair steps to the 2nd floor and 17 to the basement. On both sets of stairs there is a small landing where the stairs make a 90 degree turn (the landing effectively breaks the stairs into 6 step and 11 step segments). Had a FitBit One (lost it) that counted stairs, albeit inaccurately. Why doesn't Alta? Also, keep getting 'outdoor bike' stats even when I'm in the house all day...why?
Best Answer07-05-2016 21:57 - edited 07-05-2016 22:00
The Alta doesnt have an altimeter like your One does, therfore it can not count changes in alr8tude. No stair counting on the Alta
Best Answer09-20-2016 06:25
09-20-2016 06:25
My observations
1)Try placing the blaze on your non dominant hand .
2) Holding on to a rail while climbing stairs will disable step counts.
3)Flights of Stairs taller than 10 feet get reduced to about 4-5 steps
Best Answer09-20-2016 17:03
09-20-2016 17:03
True, the Fitbit tracker will not count floors unless it is also counting steps.
Best Answer12-06-2016 08:00
12-06-2016 08:00
As someone else mentioned, my "One" was accurate regarding floors climed, but my Blaze misses many. The problem seems to be with the Blaze. Also, you mention the metric of 10 feet. Most flights of stairs in homes are less than 10 feet.
Best Answer02-24-2017 08:00
02-24-2017 08:00
I'm in same boat. Second day, and I have stairs at home and at work. Yesterday late afternoon it counted only 1 flight, when I'd done 3 at work and 2 at home. I've climbed 3 today, and my Blaze says 0. The Charge HR was pretty accurate for me. One of the reasons I went to Blaze from Alta was I missed the functionality of the heart rate, and star climbing. I had to upgrade because I'm allergic to the plastic bands and Charge HR doesn't have interchangeability like Alta and Blaze do.
Best Answer05-07-2017 07:24
05-07-2017 07:24
Thanks for this. Have the same problem. The stairs in my house have a small landing. And I can miss 3-4 stair climbs during a day.
Best Answer05-07-2017 10:17
05-07-2017 10:17
While their is a maximum time allowed to cl8mb the stairs, a small landing should not slow a person down enough.
For floors to be counted, the tracker first needs to see that a person is walking. If no steps are being recorded, then no floors will be reworded.
Best Answer05-07-2017 11:38
05-07-2017 11:38
Well, then we are back to the ongoing issues about missing steps. The requirement for arm swinging means I can't carry anything while walking.
Best Answer02-13-2018 15:10 - edited 02-13-2018 15:12
In general you can carry something, the tracker just needs to detect steps.
There are a few ways the tracker does this by looking at arm motions. This could be the natural movement of the arm while walking or the slight up/down motion of the body that naturally happens witheach step.
If your carrying something, the arm will move up/down with this notion and steps will be counted. This would be the same as having the tracker in a pocket, where the movement is similar and steps are still counted.
That problem with a hand rail or a cart/pusher is that the bar prohibits this natural uo/down motion.
Best Answer09-09-2020 13:47
09-09-2020 13:47
Atmospheric pressure was mentioned as a factor in stair counting. The past 2 days when I walk outside my Blaze is tracking more stairs than I have done. We have been having some severe wind the past couple days with wind gusts of 30-50 m/hr. Could the wind gusts be changing the atmospheric pressure making the Fitbit record stairs I didn't do? It tracked me at like 55 flights of stairs yesterday when I did 2 flights but did a 4.25 mile walk with constant wind and wind gusts.
